Only Half Of My Porch Spotlights Work... - Electrical - DIY Chatroom Home Improvement Forum
Old 08-06-2007, 09:02 PM   #1
Only half of my porch spotlights work...
I just did my first electrical job on my new home. I didn't think I did a half-ass job, but only half the lights work. It is a project of replacing an existing porch light and daisy chaining a 2nd one to cover the back yard.
Here's the scenario. Any advice would be great.
I bought 2 "small coverage" motion sensor spotlights. The white plastic kind with the 2 big halogen spotlights.
I had an existing porch light outside which I took down and replaced with one of the new ones. I then ran a 30 inch section of 12 guage yellow wire inside a conduit tube from that light to a 2nd around the corner of the house. New outdoor electrical housing and new wire.
Before hooking up the 2nd light, I tested the first, and both bulbs lit up.
After I hooked up the 2nd light, only one bulb on each porch light lit up. I checked all the wires and they seemed fine.
Any ideas?
Thanks!
hydepark is offline   Reply With Quote
Old 08-07-2007, 03:44 PM   #2
Master Electrician
JohnJ0906's Avatar
This assumes that each flood set has a motion detector, and 2 lamp holders.
Also assumes each is seperately controlled by it's sensor.
In each flood set, there should be a black and white coming from each lamp holder, and a black, white, and red from the motion sensor.
All whites together, including incoming and outgoing power whites.
The red from the motion detector to the 2 blacks from the 2 lamp holders.
The incoming and outgoing blacks to the black from the motion sensor.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 08-08-2007, 02:51 PM   #3
Wow!
After all this, I had 2 dead bulbs. Sorry for all the excitement!
Old 08-08-2007, 07:54 PM   #4
Master Electrician
JohnJ0906's Avatar
You know, I thought of that, and didn't mention it.
I guess it's on of those things, I always check the lamps first, before anything else, and hardly think anything of it.
John from Baltimore
One Day at a Time
No Permit for my Porch and Deck jokiddjr Building & Construction 15 06-13-2007 10:34 AM
New porch light CB-PDX Electrical 4 03-09-2006 12:17 PM
PORCH - from BRICK to WOOD Kukurigu Building & Construction 1 11-12-2005 09:33 PM
Porch rebuild question Unregistered General DIY Discussions 1 11-26-2004 04:20 PM
