Old 04-10-2009, 07:09 AM   #1
Only 2 Wires??
Hi guys, I'm replacing some lights. I have an old house and I've only got 2 wires in my fan box in the ceiling, a hot and a nuetral, no ground. How do I ground my fan? Do I twist the neutral and ground together like in a stove outlet? Obviously black to black.
Thanks!
StevieL
stevieL is offline   Reply With Quote
Old 04-10-2009, 07:12 AM   #2
Only 2 Wires??
NO, do not twist Neut & grn together, never, ever!!!! How old is the house?? Are you sure there is not a ground connected to a screw in the box?? If there are only two wires, you can't connect a ground, that is allowed in old wiring. Since it is a ceiling fan, not having a ground is not essential, for other things like appliances, that is another story.
Old 04-10-2009, 07:39 AM   #3
dSilanskas's Avatar
Only 2 Wires??
If you have a metal jacket on your 2 wire the jacket is the ground and just attach the ground wire to a screw on the box. If its a two wire cable with a cloth jacket than there is no ground.
dSilanskas is offline   Reply With Quote
Old 04-10-2009, 09:41 PM   #4
Bigplanz's Avatar
Only 2 Wires??
If the fan is wired with BX cable (as is usually the case in an old house) it is probably grounded through the cable's metal jacket. Take a tester and put one probe on the hot and the other on the metal box of the fan. If it's grounded, the tester will show it.
Bigplanz is offline   Reply With Quote
Old 04-10-2009, 10:31 PM   #5
Learning by Doing
Leah Frances's Avatar
Only 2 Wires??
In my house, around 50% of the time the ground is actually there. It was just cut flush with the sheathing by the previous "electrician". Look carefully where the two wires exit any sheathing - use a flashlight and look really closely.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 07:01 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Heil DC90 - AC Wires keithshank HVAC 1 07-31-2008 09:37 PM
replacing outlet with 3 white/3 black wires gpet573 Electrical 4 06-03-2008 03:55 PM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 10:38 PM
