One Switch With 3 Potlights - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-28-2008, 11:01 AM   #16
Thanks Darren!
rellik is offline   Reply With Quote
Old 10-28-2008, 03:32 PM   #17
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
Originally Posted by jerryh3 View Post
Are you sure? Check the location of the OP.
My bad didn't look to see where OP was from. I will look up about the 80% thing tomorrow. Maybe I am not remebering what Electrical Wiring Residential By Ray C. Mullen stated. If I am wrong I appologize.
Pudge565 is offline   Reply With Quote
Old 10-28-2008, 08:35 PM   #18
Rewards Points: 2,350
The code, as far as I know, never specifically says 80%. It says that circuits for continuous loads must be sized to 125% of the load. Which, by mathematical inference, means the load must be limited to 80%. A receptacle circuit, can be loaded to 100%, and an appliance fastened in place and wired to a circuit containing other receptacles or lighting can't be more than 50% of the circuit ampacity.
Old 10-28-2008, 08:45 PM   #19
Electrician
Who cares what Ray C. Mullen has to say? Get used to the NEC, that is the only thing that counts.
chris75 is offline   Reply With Quote
Old 10-29-2008, 03:50 PM   #20
Pudge565's Avatar
Rewards Points: 150
When I read it I believe that I remember a cod reference with it unfourtunatley I had a big test in shop today so didn't get time to look it up will do that tomorrow. I will even post it there when I find it.
Old 10-29-2008, 04:00 PM   #21
Electrician
Dont waste your time, it does not exist.
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 05:53 PM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 11:05 AM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 02:53 PM
