One Switch With 3 Potlights - Electrical - DIY Chatroom Home Improvement Forum
Old 10-26-2008, 03:01 PM   #1
one switch with 3 potlights
I am in the process of running the wires in my unfinished basement. I am aware that the max. fixtures (plugs and lights) is 12, tho recomended is 8-10. My question is if I have 7 plugs can I run a single switched light with 3 potlights run off it? Or will each potlight count as one?
Thanks in advance!
rellik is offline   Reply With Quote
Old 10-26-2008, 04:43 PM   #2
Electrician
Rewards Points: 760
Each potlight will count as 1 in your count of 12.
Switches do not count toward your total, and a light with 5 lights in it(i.e a chandelier) is considered one not 5.
darren is offline   Reply With Quote
Old 10-26-2008, 06:21 PM   #3
dSilanskas's Avatar
Thanks in advance!
12 is not the max fixtures on a circuit.
dSilanskas is offline   Reply With Quote
Old 10-26-2008, 06:33 PM   #4
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
There is no limit as to how many recepticals are on a circuit. The recommended amount is 10 for a 15 amp circuit an 12 for a 20 amp. Please note however that you can only load the breaker to 80% of rated capacity.
Pudge565 is offline   Reply With Quote
Old 10-26-2008, 06:39 PM   #5
Electrician
Where is that code located?
chris75 is offline   Reply With Quote
Old 10-26-2008, 06:40 PM   #6
Electrician
Who told you that nonsense?
Old 10-26-2008, 06:42 PM   #7
Electrician
Who's recommending this? Its just a bad opinion if you ask me.
Old 10-26-2008, 07:08 PM   #8
Rewards Points: 2,350
In Canada, it is.
Old 10-26-2008, 07:09 PM   #9
Are you sure? Check the location of the OP.
jerryh3 is offline   Reply With Quote
Old 10-26-2008, 07:12 PM   #10
dSilanskas's Avatar
Originally Posted by InPhase277 View Post
In Canada, it is.
Ohhh is the OP from Canada? If so my mistake
Old 10-26-2008, 07:27 PM   #11
Pudge, check your book again. In the United States, under the NEC, the 80% factor applies to continuous to lighting circuits and other continuous loads. That is, a load that is expected to be on for 3 hours or more. Receptacles are allowed to be loaded to 100% of the circuit capacity, as long as it is a receptacle-only circuit.
The OP is in Canada, therefore, the code there allows a maximum of 12 outlets.
Old 10-26-2008, 07:27 PM   #12
Isn't pot illegal in Canada?
220/221 is offline   Reply With Quote
Old 10-26-2008, 07:45 PM   #13
Electrician
Are there not any Canadian DIY sites?
Old 10-26-2008, 08:40 PM   #14
There's at least one Canadian poster here that provides sound advice. The codes are similar enough that most are interchangeable.
Old 10-26-2008, 10:17 PM   #15
Electrician
Yeah, till you get a thread like this, I forgot to check the location of the OP, I hate when I do that.
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 06:53 PM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 12:05 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 06:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
