One Source, Two Switches AND A Through Power/source - Electrical - DIY Chatroom Home Improvement Forum
Old 10-29-2010, 10:36 PM   #1
Rewards Points: 141
Talking
One source, two switches AND a through power/source
I believe I understand how to connect two switches in a double switch box with one power source. (All whites together, incoming black hot is wired nutted to two black branches each going to a switch. The black hot continues through each switch via connection to blacks from the separate light units. All grounds are nutted together but with two added branches one each to the ground connection on the switch, I'm using a plastic box.) BUT, TO THIS CONFIGURATION I also want one source out to go to one more nearby light which will have a switch in a different single switch box. How to I create a through wire out of the double switch box in this situation? Do I simply just add the black, white and grounds of the through/out wire to the respective group nuttings of each color? Thanks.
DiegoJames is offline   Reply With Quote
Old 10-29-2010, 10:38 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 658
Thats how you do it.
You must make sure the box is large enough for the extra wires.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
DiegoJames (10-29-2010)
Old 11-14-2010, 10:34 AM   #3
Rewards Points: 141
Cool
thanks
Thanks jbfan:
It in and working!
two switches, two sets of lights one power source agsurfer Electrical 2 09-12-2010 09:23 AM
Question about wiring and voltage with switches and lights rswurth Electrical 17 06-20-2010 11:12 PM
Question about switches on a 20 amp circuit Abs777 Electrical 6 04-28-2010 10:09 AM
Bathroom Lighting From One Source to two switches Michblaze02 Electrical 4 11-16-2009 05:10 AM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 09:40 PM
