One Side Of Double Pole 100 Amp Breaker - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-13-2012, 09:40 PM   #16
Rewards Points: 506
Originally Posted by gregzoll
Nothing to do with Ohm's law. Breakers go bad, whether they are a Single pole or double pole. Just because you have two poles on a breaker, one pole can go bad, while the other still works fine.
Even more fun, when you have a 400amp breaker blow, causing the other phase to blow out that side. Nice fourth of July action.
Obviously a failed breaker could allow ZERO volts to be realized. I mistakenly interpreted your comment to mean that a faulty breaker could allow a partial voltage to be realized. Say, 50 volts for example.
jlmran is offline   Reply With Quote
Old 12-13-2012, 11:07 PM   #17
" Euro " electrician
frenchelectrican's Avatar
I just replace big 1600 amp breaker for my industrail customer it was no fun with that one it did knock the POCO transfomer out of commison end up replace that as well. ( BTW it is 415Y240 volt system )
I have see some three pole breaker go bad on one " phase " ditto with common 2 pole breakers.
Merci,
Marc
Old 12-13-2012, 11:10 PM   #18
If you did get 50 volts going thru the breaker like example then you have something is burning inside the breaker useally the concat is bad or pitted up pretty serious. For sure you can hear the cracking sound ( I can pick up the viberations so I know it is cooking pretty hard )
Sometime you can get the larger two pole breaker like main breakers it can do show up in funny way depending on what model it is.
Merci,
Marc
Old 12-14-2012, 05:57 PM   #19
Rewards Points: 12
Thanks for all the help from everyone..It was corrosion where the breaker in the main box connected to the power..
ndmick is offline   Reply With Quote
Now, Square D Combo AFCI Breaker Trips Opens w/No Load Side Connections QO120CAFI mysterylectric Electrical 14 10-27-2013 02:51 PM
Double Pole 15A on/off switch?? Skelleyman Electrical 5 05-01-2012 04:01 PM
How to create flat surface on side of round pole Silkcityflorida General DIY Discussions 16 02-01-2012 10:01 AM
Wierd Double Pole Breaker Occurance rlemar Electrical 5 02-16-2010 09:43 PM
Double pole CH breaker ?? James Con Electrical 7 07-09-2008 11:41 PM
