One Side Of Double Pole 100 Amp Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 12-13-2012, 06:19 PM   #1
Rewards Points: 12
one side of double pole 100 amp breaker
Can just 1 side of a 100 amp double pole Circuit Breaker go bad?
ndmick is offline   Reply With Quote
Old 12-13-2012, 06:22 PM   #2
Rewards Points: 506
My guess is yes.
jlmran is offline   Reply With Quote
Old 12-13-2012, 06:24 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
For sure
The Following User Says Thank You to k_buz For This Useful Post:
Speedy Petey (12-13-2012)
Old 12-13-2012, 06:28 PM   #4
Rewards Points: 12
Thanks .I feed a subpanel thru a 100 amp breaker and 1 side of the sub is not working(not getting full amps) even with none of the curcuits in the panel on, keeps popping 1 side of breaker.
Old 12-13-2012, 06:38 PM   #5
Rewards Points: 506
It's impossible for only one side of a 2 pole to "trip". Please describe further.
Old 12-13-2012, 06:42 PM   #6
Rewards Points: 12
It doesn`t completely trip but it doesn`t let full voltage thru the 1 side (1 feed to the sub panel )some voltage but not all.Seems like 1 side doesn`t catch when resetting it
Old 12-13-2012, 06:45 PM   #7
Rewards Points: 506
How/where are you measuring voltage? At the suspect breaker? At the subpanel? What is your reference?
Seems odd to me that a breaker is responsible for a "reduced voltage".
Old 12-13-2012, 06:48 PM   #8
Semi-Pro Electro-Geek
Rewards Points: 2,938
It's not really possible for a breaker to "not let full voltage through". It's either on or off. Could be a bit loose, but that would only be apparent under heavy load and would cause major heating. You need to do some measurements and describe in detail exactly what your observations are.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 12-13-2012, 06:49 PM   #9
Rewards Points: 6,652
Yes it can.
Old 12-13-2012, 06:50 PM   #10
Rewards Points: 12
measuring at the subpanel where it goes into the main breaker.
Old 12-13-2012, 06:53 PM   #11
Rewards Points: 506
Originally Posted by gregzoll
Yes it can.
How can this be explained in the context of Mr. Ohm?
Old 12-13-2012, 06:55 PM   #12
Rewards Points: 506
What are your contact locations? Line to line? Line to neutral? Line to ground? What is the value of the reduced voltage?
Old 12-13-2012, 06:59 PM   #13
Rewards Points: 12
line to neutral
Old 12-13-2012, 07:00 PM   #14
Rewards Points: 12
Thanks to all that helped I`ll go pick up new cuircuit breaker in the morning .I`ll come back on friday night let you all know the results.
Old 12-13-2012, 07:49 PM   #15
Nothing to do with Ohm's law. Breakers go bad, whether they are a Single pole or double pole. Just because you have two poles on a breaker, one pole can go bad, while the other still works fine.
Even more fun, when you have a 400amp breaker blow, causing the other phase to blow out that side. Nice fourth of July action.
Now, Square D Combo AFCI Breaker Trips Opens w/No Load Side Connections QO120CAFI mysterylectric Electrical 14 10-27-2013 02:51 PM
Double Pole 15A on/off switch?? Skelleyman Electrical 5 05-01-2012 04:01 PM
How to create flat surface on side of round pole Silkcityflorida General DIY Discussions 16 02-01-2012 10:01 AM
Wierd Double Pole Breaker Occurance rlemar Electrical 5 02-16-2010 09:43 PM
Double pole CH breaker ?? James Con Electrical 7 07-09-2008 11:41 PM
