One Recessed Light On Two Different Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 09-25-2007, 11:44 PM   #1
one recessed light on two different switches
I have two hallways, each with their own recessed lighting that meet at an intersection. They are on the same 15A breaker but each hall has 3-4 canned lights on seperate switches. For example, one hallway can be illuminated and the other one can be dark, or both can be on if you turn on both switches.
The problem is that I want ONE recessed light where the hallways intersect to be on when either hallway light is switched on. How would I wire this? I can't just wire it at the end of both switch circuits because that would cause all of the lights in both hallways to be illuminated when either switch is turned on, right?
bjherron is offline   Reply With Quote
Old 09-26-2007, 06:35 AM   #2
Electrician
This would require the use of a relay...
chris75 is offline   Reply With Quote
Old 09-26-2007, 12:17 PM   #3
Rewards Points: 150
Or dual pole switches.
scorrpio is offline   Reply With Quote
Old 09-26-2007, 01:55 PM   #4
" Euro " electrician
frenchelectrican's Avatar
There is a other idea this done in commercal area ,..
motion sensor or occupuation sensor that will do the trick.
Just mount it on the ceiling if that possible and aim it down if the sensor can read that driection because if you walk in the hallway in one driection when you approach the intersection the indivual ressced can luminaire will kick on it own so you dont have to worry about the switch or relay
just a thouht
Merci , Marc
Old 10-01-2007, 12:18 AM   #5
Contractor in PA
You do not say what style recessed lights you have. You could change out the center recessed light (the one that you want to light from both switches) and install a recessed fixture that has two lamp holder in it. Then feed each lamp holder separately from the two switches. Admittedly, the new fixture may need to be different than the rest of the existing fixtures. You should also label the inside of the fixture that there are two circuits within the fixture.
michaelpwalton1 is offline   Reply With Quote
3 switches 1 light. need 2 lights 2 switches. Im desprete s richards Electrical 6 07-19-2008 04:18 PM
2 switches to same light use 1 for another light gmcclel Electrical 9 05-29-2007 02:30 AM
Where to buy paddle light switches in bulk? Proulx06 Electrical 3 05-21-2007 07:43 AM
Recessed light plan foiled? kcrossley2 Electrical 8 03-15-2007 12:08 AM
recessed light farrington135 Electrical 3 12-03-2006 01:02 PM
