Old 02-09-2011, 09:52 PM   #1
One problem causes chain of circuits to go off
Something got dropped into my upstairs bathroom light socket and caused a short, so the switch on the downstairs circuit breaker was thrown. I removed the object and turned the switch at the circuit breaker for the bathroom lights back on. When I threw this switch it somehow caused the outlets for a room on the other side of the house to go out and the switch for that room’s circuit breaker was thrown. I turned that switch back on and somehow the lights for the basement went out.
None of these lines are on the same circuit, and they are not related in any way that I know of. Please tell me what happened. This has never occurred before.
Thanks in advance to all who help.
Cossack is offline   Reply With Quote
Old 02-10-2011, 12:21 AM   #2
" Euro " electrician
frenchelectrican's Avatar
By slim chance you may have MWBC { Multi Wire Branch circuit } if that the case you can effectaly kill it if the netural open up or any connection at one of the juncion boxes like other receptale and switches.
How many diffrent breaker you hit so far if two then that is the answer but if more than two diffrent breakers then we will go one step a time to troubleshooting this one { it will not be a easy task but it can be done if you understand this }
So therefore with some hevey short circuit some of the loose connection or subpar connection effectaly open up this is true with backstabbing switch or receptales they are famous for that.
Poor maded wirenut connection will do the same thing.
The last thing how old this house is ??
Merci.
Marc
Old 02-10-2011, 07:36 AM   #3
Check and retighten all the screws and setscrews in the breaker panel used to hold wires in place. (Turn off each breaker before touching its screw).
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded.
Old 02-10-2011, 08:32 AM   #4
Licensed electrician
Originally Posted by sanny View Post
It is the problem in your circuit check is there any fluctuation is happening there. Other wise you have to change whole wires.
As has been pointed out by an electrician on this board, the problem sounds like a loose connection. The cabling in the wall should not have to be replaced.
Old 02-10-2011, 08:48 AM   #5
Jim:
I do not understand where I am to look for the "loose connection." The screws holding the wires inside the circuit breaker?
Old 02-10-2011, 08:50 AM   #6
Also at every switch box or receptacle along the way (daisy chain) to the dead light or receptacle.
Old 02-10-2011, 11:03 AM   #7
Ok, I will try all that, but why would fliping one switch at the circuit breaker affect other unrelated circuits?
Old 02-10-2011, 11:59 AM   #8
Master Electrician
Are the breakers in the panel all firmly seated upon the busses
brric is online now   Reply With Quote
Installing vinyl fenching over chain link? rbove8 General Discussion 3 05-02-2011 10:54 PM
septic problem??? jjrbus Plumbing 2 09-09-2009 10:59 PM
Weed problem, bug problem, or both? hayzen Landscaping & Lawn Care 1 08-25-2009 07:33 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
