One Outlet Testing At 115 Volts - Electrical - DIY Chatroom Home Improvement Forum
Old 10-03-2009, 08:32 PM   #1
Rewards Points: 89
one outlet testing at 115 volts
I was testing my outlet in my house and all of them came out with about 125 V. However, my outlet that is located outside my house, about 20 feet away tested at 115 volts. Do I have a problem are is this normal since this outlet is located outdoors.
stanlam is offline   Reply With Quote
Old 10-03-2009, 08:36 PM   #2
dSilanskas's Avatar
That's fine a little low but nothing to be worried about
dSilanskas is offline   Reply With Quote
Old 10-03-2009, 08:49 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
120 V is the US standard, so you are right in the middle.
Voltage varies depending on how much of a load because of wire Resistance.
Outside or Inside does not make any difference.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 10-03-2009, 08:56 PM   #4
Originally Posted by stanlam View Post
outlet in my house
about 125 V.
To drop 10v across 20' of #14 Romex you'd need to pull 100A. I'd say you have a problem unless the voltage in the house measured 115v at the same time as you measured the outside voltage.
Old 10-03-2009, 09:18 PM   #5
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
Are the outlets on opposite legs? Sounds like the neutral may not be tapped at exactly the center of the transformer (power company issue). I could be wrong though. Though think that difference may be fine. I'd be more concerned about the 125 then the 115, but even then lot of devices are rated for 125.
Old 10-03-2009, 09:52 PM   #6
Rewards Points: 89
it lost 10 volts with no amps being used
The wiring from the circuit breaker to the outlet is very old. At least 60 years old. Therefore, I don't even know if Romex was made back then. It's just two wires inside a metal pipe that runs underground from the circuit breaker to the outlet. I think the wire is more like 40 feet then 20 feet.
If you test the voltage directly from the circuit breaker that leads to this outlet, it reads 125 volts. I did this test not using any electricity at all, therefore during the test the electrical meter didn't move at all. It's just a drop of voltage with no amps being used.
Is there any test I can run to make sure this thing is safe. This outlet hasn't been used for at least 15 years. I want to use it now but I just want to make sure it's safe.
Old 10-03-2009, 10:00 PM   #7
Rewards Points: 89
The neural for this wiring goes directly to the fuse box neutral. The hot wire goes directly to the circuit breaker. The wire is actually more like 40 feet then 20 feet.
Old 10-04-2009, 06:53 AM   #8
Code05's Avatar
Rewards Points: 1,104
If the wire is in pipe/conduit and you suspect there is a problem, pull new wire and put in a new receptacle. I would pull a ground wire also. 50 feet of wire and a receptacle is probably 20-25$.
Code05 is offline   Reply With Quote
Old 10-04-2009, 07:06 AM   #9
Tool Geek
PaliBob's Avatar
....... At least 60 years old.
........, I don't even know if Romex was made back then.
Romex has been around since 1922 ( I'd love to see some of it)
You don't have Romex in that "metal pipe". That is most likely rigid conduit.
Which is similar to old fashioned threaded gas pipe.
With no current, there should be no voltage drop between the panel and the receptacle.
With wiring that old, I would not be asking if it is safe, I would replace it.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 10-04-2009, 07:32 AM   #10
Rewards Points: 1,536
1. Make several measurements a few minutes apart, at the receptacle (outlet) in question and at several places in the panel including the breaker for this outdoor run. Just in case voltage to the entire house fluctuated between your measurements, and also in case you didn't make good contact in the receptacle that hasn't been used for a long time and might be a bit oxidized (rusty).
2. I would give the circuit a test with about 300 watts; more than one incandescent light fixture out there might do it. Near zero voltage change out there with the lamps on versus off means no problem. If you indeed measured a difference of 120 versus 115 volts at the panel versus at the receptacle with (essentially) no load, then the lamps would cause a tremendous voltage drop instantly giving away the existence of a problem.
Old 10-04-2009, 08:05 AM   #11
I'd pull new wire & put in a new outlet
I'd also GFCI protect the wire before it goes outside
I use a GFCI outlet inside to protect my outside outlets
Old 10-04-2009, 09:14 AM   #12
Yes.
Even it tests good today it may fail tomorrow. But make sure the problem is in the wire and not farther upstream.
Old 10-04-2009, 10:38 AM   #13
Guest
It's definitely not ok. There are a number of reasons for voltage drop. You just have too much resistance. 5% drop max. 125 x .05 = 6.25. 125 - 6.25 = 118.75. Test the resistance. Know your Ohms.Long story short, do as some others have said, repull it. Pull 3 12awg THWN. Not THHN, white, green, black. You don't know what kind of shape the pipe is in. Turn off the breaker, disconnect the hot, remove the outlet outside, see how free the wires move. Tie on or fish tape it. Be careful, old pipe could cut the insulation. New GFCI outlet outside. Don't use GFCI breaker. Waterproof the housing.
connyou is offline   Reply With Quote
Old 10-04-2009, 11:10 AM   #14
Rewards Points: 1,016
Ensure all the connections for that circuit in the panel and at the outlet are clean and tight. If there a junction box or other connection between the panel and the outlet - if so, ensure they are clean and tight. The outlet should be a GFCI anyway, so just replace it. If after these actions the problem persists, run a new wire.
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Help Help richie02 Electrical 7 06-17-2008 08:42 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
Looking for help in testing why switched outlet is always hot geocrash Electrical 3 11-26-2007 07:15 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
