Old 07-09-2008, 12:03 AM   #1
Question
On one outlet my GFCI tester has all three lights lit. What does it mean?
? The diagram provided by the manufacturer covers every case except the one I have. I have disconnected an appliance from the outlet (toaster oven) but I have the same result. All three lights are lit.
On one outlet my GFCI tester has all three lights lit. What does it mean?-image.jpg
Deck is offline   Reply With Quote
Old 07-09-2008, 06:45 AM   #2
Electrical Contractor
wirenut1110's Avatar
Send a message via AIM to wirenut1110
Based on your other question, is your neutral and ground reversed?
wirenut1110 is offline   Reply With Quote
Old 07-09-2008, 08:24 AM   #3
Maybe the tester is bad.
BillyD is offline   Reply With Quote
Old 07-09-2008, 10:19 AM   #4
Moderator
Termite's Avatar
In several years as an inspector, I've been led astray by a number of testers. They can get quirky sometimes. I go through at least two a year, no matter what brand I buy, because mine get used constantly. I'd suggest trying a new tester and going from there.
Old 07-09-2008, 12:46 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Take out your grounding type outlet (receptacle) you have a hot neutral interchanged and you have a bootleg ground....small jumper from the neutral screw to the ground screw. This only occurs on wiring systems that do not have the equipment ground in the wiring system...just two wires black and white no grounding wire or metal conduit. If you have the equipment ground in the wiring and connected to the receptacle ground screw then I'm not sure what your problem may be other than a faulty tester but you say it works correctly on other outlets.
Old 07-09-2008, 09:18 PM   #6
Thanks for the info guys.
I'm going to get a new tester to be safe. I went to Home Depot today and the 3-prong testers are only the Sperry type. They don't sell any other 3-prong testers. What would be a good tester if I wanted to test ground, neutral, and hot?
I've got a lot of stuff in my house that has old armor cable with these wires in some type of cloth... but all the wires look the same. There is no difference to any of the wires. So I'd like to test them for hot /ground /neutral.
Old 07-09-2008, 10:18 PM   #7
That's a separate issue on another circuit. It appears that:
hotwire runs to fan neutral
neutral runs to fan light
ground runs to fan hotwire
when I flick the switch the light goes on and off. the fan goes on regardless of the state of the switch; it is controlled by a pull chain. ran fine for probably 20 years.
Treadmill on GFCI outlet? fw2007 Electrical 13 10-21-2008 02:49 PM
GFCI Question Mdbuilder Electrical 6 06-19-2008 04:15 PM
Bathroom Vanity Lights... after GFCI? CuCullin Electrical 4 11-12-2007 04:16 PM
GFCI Outlet installation in bathroom... budde97 Electrical 4 02-11-2007 01:22 AM
Outlet in bathroom for lights.... TerryL Electrical 5 10-28-2006 09:46 PM
