-   -   On one outlet my GFCI tester has all three lights lit. What does it mean? (http://www.diychatroom.com/f18/one-outlet-my-gfci-tester-has-all-three-lights-lit-what-does-mean-23391/)
Deck 07-08-2008 11:03 PM
1 Attachment(s)
? The diagram provided by the manufacturer covers every case except the one I have. I have disconnected an appliance from the outlet (toaster oven) but I have the same result. All three lights are lit.
http://img59.imageshack.us/img59/1927/imagenh7.jpg
wirenut1110 07-09-2008 05:45 AM
Based on your other question, is your neutral and ground reversed?
BillyD 07-09-2008 07:24 AM
Maybe the tester is bad.
Termite 07-09-2008 09:19 AM
In several years as an inspector, I've been led astray by a number of testers. They can get quirky sometimes. I go through at least two a year, no matter what brand I buy, because mine get used constantly. I'd suggest trying a new tester and going from there.
Stubbie 07-09-2008 11:46 AM
Take out your grounding type outlet (receptacle) you have a hot neutral interchanged and you have a bootleg ground....small jumper from the neutral screw to the ground screw. This only occurs on wiring systems that do not have the equipment ground in the wiring system...just two wires black and white no grounding wire or metal conduit. If you have the equipment ground in the wiring and connected to the receptacle ground screw then I'm not sure what your problem may be other than a faulty tester but you say it works correctly on other outlets.
Deck 07-09-2008 08:18 PM
Thanks for the info guys.
I'm going to get a new tester to be safe. I went to Home Depot today and the 3-prong testers are only the Sperry type. They don't sell any other 3-prong testers. What would be a good tester if I wanted to test ground, neutral, and hot?
I've got a lot of stuff in my house that has old armor cable with these wires in some type of cloth... but all the wires look the same. There is no difference to any of the wires. So I'd like to test them for hot /ground /neutral.
Deck 07-09-2008 09:18 PM
That's a separate issue on another circuit. It appears that:
hotwire runs to fan neutral
neutral runs to fan light
ground runs to fan hotwire
when I flick the switch the light goes on and off. the fan goes on regardless of the state of the switch; it is controlled by a pull chain. ran fine for probably 20 years.
