One Messed Up Panel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-12-2013, 02:28 PM   #16
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,534
Originally Posted by bobgodd View Post
If he removes the breaker for the heaters, but cannot remove the wire, what is the proper way to terminate the wire?
wirenut
MTN REMODEL LLC is offline   Reply With Quote
Old 05-12-2013, 02:53 PM   #17
" Euro " electrician
frenchelectrican's Avatar
Most common methold is wirenut and make a note on them what it used to be served on that former circuit due some case it can be repurposed for other useage depending on conductor size.
Merci,
Marc
Old 05-12-2013, 03:43 PM   #18
Merci,
Marc
I like to label them by taking a short 1" or so piece of Romex sheathing, labeling with a Sharpie pen, and slipping it over the wire. I think the yellow (#12) looks good.
Coil or bend that wire neatly and tuck it away neatly in a corner.... I know that box is probably a rat's nest anyway.
Old 05-12-2013, 09:08 PM   #19
That is pretty common way to do that.
But for me I don't useally coil it up I just fold it up and tuck it out of the way so you know that is a " spare " circuit which it can be reused but all it depending on conductor size.
Merci,.
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
MTN REMODEL LLC (05-12-2013)
Old 05-13-2013, 01:09 PM   #20
Special User
Rewards Points: 1,230
From what I understand, it is permissible to abandon wires in walls etc only if BOTH ends of the wires are abandoned. As long as one end still comes into a box (like the breaker box), the other end (like at the heater) needs a box and cover plate too.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 05-13-2013, 01:24 PM   #21
Don't know that code book very well... but it's sure a good idea. Plus why would you leave them in the panel, if you can't get to them in the wall.???
Sub panel to sub panel feeding tvfd27 Electrical 1 08-21-2012 03:01 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 07:24 AM
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 10:03 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
