One Messed Up Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 05-11-2013, 05:36 PM   #1
Rewards Points: 528
one messed up panel
one messed up panel-imag0496.jpgJust got the place and there are several violation I I'll need to clear up,not to mention may have to move panel. Is is required when I cap off or disengag circuit that I move live circuits to top and cover plates below or is it OK to let them remain capped off?
Its seimans breakers .
It had baseboard heater circuits now no longer used.
Any info on it is appreciated.
hidden1 is offline   Reply With Quote
Old 05-11-2013, 05:39 PM   #2
eastcoastsparky's Avatar
Rewards Points: 150
Why do you hav to move the panel? Where is it located? Add you location to your profile. And yes it does matter
eastcoastsparky is offline   Reply With Quote
Old 05-11-2013, 05:44 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,834
Is your issue that you want to remove the breaker and the feeds to your formerly used baseboard heaters?
MTN REMODEL LLC is offline   Reply With Quote
Old 05-11-2013, 05:47 PM   #4
Rewards Points: 150
I think he wants to know when you remove the circuits that are at the top of the panel if it is required to move lower circuits up to that position and to install blanks for the repositioned breakers
Old 05-11-2013, 05:48 PM   #5
Rewards Points: 528
It has central heat/air so i m sure they are no longer needed/used
Old 05-11-2013, 05:51 PM   #6
Rewards Points: 150
So what is your actual question?
Old 05-11-2013, 05:58 PM   #7
Rewards Points: 528
Will I have to move the operative circuits up and the disengaged to bottom,capped off?
And what gauge/amp wire are usually used in baseboard heating?.I will have to set up a seperate circuit for disposal and another for possible over stove microwave also.
Old 05-11-2013, 06:20 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Try re-posting when you are sober
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 05-11-2013, 06:28 PM   #9
Caveat.. I'm not a sparky and not always (often) up to date on codes. I only answer so one of our sparkys can correct me
To the best of my knowledge: You do not have to rearrange or move lower breakers to the top, if that is your question. (In my jurisdiction, you do have to have all your main shutoff's ,less than 6... when you do not have a master... at the top). (Also, you do want to keep somewhat a balance between your two legs)
Disconnect your breaker feeds and neatly wire cap/label them and leave them in your panel for future use if you want.
You do not have to remove your breaker... but if you do... put the plastic blank in.
Your baseboards can be fed by various AWG wire, depending primarily on whether your running them 240 or 120... and some other factors. When you disconnect them, look at them and read the print on them.
I'm confused about your disposal microwave issue.
Good luck
Old 05-11-2013, 06:38 PM   #10
Rewards Points: 528
Currently the disposal is on same circuit as kitchen plug which is a violation.also I'm going to install a over the oven microwave(requires dedicated circuit 20 amp) .would like to use circuit that is no longer used for baseboard heater. So I can cap off the rest of unused baseboard circuits and leave in place then ,then put a cover plate over it?
Thanks for the info
Old 05-11-2013, 08:01 PM   #11
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
I don't think you have to move the in use breakers all to the top, though it might LOOK neater and be easier to see, but if you remove unused breakers you need to cover those holes with those blank covers so someone can't accidentally stick a finger in the hole- think of fumbling in the dark trying to find the breaker that tripped and you can see why you wouldn't want any way to accidentally get fingers in.
RWolff is offline   Reply With Quote
The Following User Says Thank You to RWolff For This Useful Post:
sirsparksalot (05-12-2013)
Old 05-12-2013, 08:33 AM   #12
joed's Avatar
Rewards Points: 12,892
When you disconnect the baseboards you can leave the breakers in place to fill the holes that would be present in the panel cover. No need to move the other breakers up. If you remove the cable then the holes in the side of the panel will need plugs installed.
If you need to add a new circuit then you can remove an unused breaker and put you new circuits in that slot.
The Following User Says Thank You to joed For This Useful Post:
usair (05-12-2013)
Old 05-12-2013, 11:29 AM   #13
Master Electrician
Rewards Points: 3,870
gtfooh
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
MTN REMODEL LLC (05-12-2013)
Old 05-12-2013, 11:39 AM   #14
An old Tradesmen
Rewards Points: 7,344
Please don't quote the spam. Doing so could get you accidentally banned as a spammer, if we don't notice its just a quote. We don't actually read the spam post. We just click the box, delete and ban.
Old 05-12-2013, 02:17 PM   #15
bobgodd's Avatar
Rewards Points: 101
If he removes the breaker for the heaters, but cannot remove the wire, what is the proper way to terminate the wire?
bobgodd is offline   Reply With Quote
Sub panel to sub panel feeding tvfd27 Electrical 1 08-21-2012 03:01 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 07:24 AM
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 10:03 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
