One Light Kills Bulbs Too Fast - Electrical - DIY Chatroom Home Improvement Forum
Old 01-20-2010, 09:01 AM   #1
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
One light kills bulbs too fast
i have two exterior coach lights on either side of my garage door. They are both wired to the same switch. For some reason i have noticed that every six months or so i need to replace the bulb on one side ( the side furthest from the switch) I have tried incadescents, CFs, halogens, and even LED bulbs, (changing both bulbs at the same time) but it seems no matter what i try, that one side seems to kill the bulb prematurely.
any ideas
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 01-20-2010, 11:02 AM   #2
Household Handyman
Rewards Points: 1,408
I read an article on this, I have used this method on some customers light fixtures which had a history of bulbs burning out "prematurely", and it seems to work, so far. With the power to the fixture turned OFF, and I'd rather this be at the breaker than the switch. Reach into the socket itself with a pair of thin needle nose pliers and gently pull the brass looking (most of them are) tab outward/forward just a little. These "HOT" tabs (according to this article) tend to get bent back too far as people screw light bulbs into the sockets too tightly, and eventually will not have the "spring" necessary to make good contact with the base of the bulb. This will create a very small contact surface that theoretically can cause arcing and lead to shorter light bulb life. Then, when replacing the new bulb, only screw it in until it lights up. As I stated, this has seemed to work on some light fixtures I have tried it on. I will say that some of the plastic fixtures with the cheap lamp bases are just pure junk and cannot be saved, replace them. Good Luck , David
Old 01-20-2010, 11:27 AM   #3
Lightbulb
I agree with your conclusions and remedies. But in some cases as in the one of the OP (and in mine and many others) the problem tends to be with EXTERIOR lights. MY conclusion would have been that the problem is weather-related. In my particular case, the problem was resolved by using CFL bulbs. !
spark plug is offline   Reply With Quote
Old 01-20-2010, 11:35 AM   #4
Learning by Doing
Leah Frances's Avatar
Weather related could still be that the metal 'spring' needs adjusting anyway. I seem to remember something from college physics about metal shrinking and expanding with temperature changes.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-20-2010, 11:43 AM   #5
Another weather factor would be moisture. Is your fixture still relatively sealed against wind-driven rain? My neigbor had a fixture, but the top was a bit deformed, and allowed some moisture instrusion into the lamp/socket area. I suspect this caused a lot of bulb failures, as well, possibly contributing to an arcing problem. A new fixture solved their problems. Short of that, make sure things are as rain resistant as they should be.
oberkc is offline   Reply With Quote
Old 01-20-2010, 02:21 PM   #6
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
i origanilly thought it was weather, made extra sure they were sealed about three bulbs ago. i will try the tabs. i also have two ceiling mounted interior lights in my garage with the same problem. the funny thing is the two problem sockets are on same side of garage, but one inside and one outside....
thanks, i will give it a try
Old 01-20-2010, 04:09 PM   #7
jlhaslip's Avatar
Rewards Points: 2,812
is that side of the garage also have a passage door?
I have a bulb issue with the fixture besdie the passge door of my shop.
I think it is due to vibrations when closing the door. (jiggles the filament)
jlhaslip is online now   Reply With Quote
Old 01-21-2010, 08:16 PM   #8
Thumbs up
I agree. It nearly drove me out of my mind (Whatever is left of it). Thanx!
Old 01-21-2010, 08:19 PM   #9
Smile
My original problem (and many others that I was asked about) was where the area was protected from moisture but not from wind and frigid temperature. I think Poster Leah Frances had it right. It makes sense!!
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Light bulbs blowing,,, Woodcutter Electrical 12 09-15-2009 06:24 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Light bulbs burning out Michblaze02 Electrical 12 03-19-2009 12:18 PM
Ceiling Fan Light Bulbs? kennykenny Electrical 7 07-29-2008 07:16 AM
