One Duplex Receptacle Split To Be Controlled By 2 Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 01-16-2014, 05:22 PM   #1
Rewards Points: 83
One duplex receptacle split to be controlled by 2 switches
Hi. Just wanted to ask if I could run 3 wire cable (black,red,white with ground) to a duplex receptacle (breaking the tab on the hot side) in order to switch the top half of a duplex receptacle with a 3 way switch and the bottom half with a single pole switch?
pex006 is offline   Reply With Quote
Old 01-16-2014, 09:40 PM   #2
Msradell's Avatar
Rewards Points: 170
Yes, what you are proposing is acceptable by code.
Msradell is offline   Reply With Quote
Old 01-16-2014, 09:58 PM   #3
Rewards Points: 2,516
Yes.
But in the diagram grounds not shown for ease of drawing
hammerlane is offline   Reply With Quote
Old 01-16-2014, 11:01 PM   #4
Rewards Points: 83
Thanks! That's exactly how I was thinking of wiring it. What do you mean by no neutral on the second 3-way switch or the code police will get you. Do you mean to make sure I mark it black so it is identified that I am using it as a hot wire?
Old 01-16-2014, 11:27 PM   #5
Rewards Points: 512
2011 NEC requires that a neutral be at each switch, a requirement that your locality may or may not require.
Installation is the Reverse of Removal.
Old 01-16-2014, 11:32 PM   #6
Rewards Points: 83
Oh. Throws a kink in my plan then. Does that mean you can't back feed a switch anymore if power comes into the fixture instead of the switch box since there would be no neutral? Maybe I'm just not understanding this correctly.
Old 01-17-2014, 12:26 AM   #7
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Id just run a piece of 14/4 if you want to run it from existing outlet box before the switch, that way you have a neutral in the box.
Are you switching it from multiple locations?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-17-2014, 12:26 AM   #8
Rewards Points: 83
So I will have to use a 4 wire cable (plus a grounding conductor) to be code compliant with the 3-way switches and just have some white neutrals with a cap on it hanging in the switch boxes? And if back feeding a single pole switch I will have to use a 3 wire cable (plus a grounding conductor) and have a white capped in the switch box? Correct?
Old 01-17-2014, 12:34 AM   #9
plummen's Avatar
That will work for the feed side of a pair single pole or 3 way
Switches.
If you were feeding the switch box first youd be able to run 14/3 to
Feed the outlet.
Old 01-17-2014, 01:38 AM   #10
As sirsparksalot said, a neutral is required at switch locations now if your locale has adopted the new code.
If you never plan on putting a timer or motion sensor in the box then I won't tell that there is no neutral there. In my opinion not a big deal. But if you get some 14-4 cable just cap the neutral of in the box.
Old 01-17-2014, 12:24 PM   #11
Rewards Points: 83
Thanks for all the help everyone.
Old 01-17-2014, 06:40 PM   #12
Rewards Points: 83
Hi. One more question. I want to do this this with 4 duplex receptacles in the room. I plan to bring the 3 wire cables from these 4 receptacles to a large junction box and connect the all reds to the red switchleg and all the blacks to the black switchleg. Correct?
Old 01-17-2014, 09:21 PM   #13
Msradell's Avatar
Rewards Points: 170
That's fine as long as he junction box remains accessible and you use the proper sized wire nuts for the connections. It might be easier and take less wire just daisychain the receptacles with 3 conductor wire.
Old 01-17-2014, 10:02 PM   #14
Rewards Points: 83
Thanks for the help.
Old 01-23-2014, 06:44 PM   #15
Rewards Points: 83
One last question. I have a bit of a shallow wall to deal with for this and was wondering if there is any problem with putting in a 4 square box with two duplex receptacles and switch each duplex on separate switches(one with the red hot wire and one with the black hot wire) instead of splitting one duplex receptacle? I figure I waould just need to pigtail the neutrals together. I already have the required constant non-switched receptacles accounted for the walls in this area. These switched receptacles are for lamps and christmas/holiday lighting only.
low voltage reading at receptacle 2 ball cane Electrical 5 04-06-2011 12:07 AM
Wiring A Ceiling Fan, Receptacle, and Outside Light merlin6984 Electrical 9 03-26-2009 09:52 PM
split receptacle with 3 way switch handifoot Electrical 5 02-26-2009 10:05 PM
Split Circuit Receptacle buster666 Electrical 5 02-25-2009 07:28 PM
Split Receptacle on 3-Way Circuit NPS Electrical 6 11-03-2005 09:28 AM
