One Breaker Trips When I Turn Another Breaker On - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-18-2014, 09:00 PM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,972
That's great that you're at least very well prepared. You'd love to see the questions we get just like yours and folks don't even own a simple tester.
Old 02-18-2014, 09:01 PM   #17
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I'm the same way, it would bug me too. I was just suggesting an easy solution.
Old 02-18-2014, 09:03 PM   #18
From Philadelphia
Rewards Points: 289
I definitely appreciate you verifying that this "okay" to do. I couldn't find a reason why it wouldn't be okay, but it's good to hear that it went through someone else's brain too.
Thanks for all the answers so far guys; I appreciate it. I suppose tomorrow I dig around a little more and see what I can find. Any more tips, feel free to keep chiming in.
hellohello is offline   Reply With Quote
Old 02-18-2014, 09:10 PM   #19
Rewards Points: 240
Here's a theory: there used to be two separate circuits, but at some point their hots got tied together in a box somewhere. But they're on different legs, so when both breakers are on, there's a dead short across the two legs. With either breaker on and the other one off, the circuit works. (Although it may be heavily loaded because it is, in effect, two circuits' worth of stuff.)
If I were going to try to diagnose this, I'd start by looking at all of the multi-gang boxes, looking for one that appears to have a feed that goes nowhere. Disconnect that feed, then switch the breakers (turn the first one off, then the second one on) and see if the "dead" feed suddenly becomes live.
fa_f3_20 is offline   Reply With Quote
Old 02-18-2014, 09:13 PM   #20
dmxtothemax's Avatar
Rewards Points: 5,498
Have you positively identified the type of breakers used ?
Could be that they are "Arc Fault Circuit Interuptors" ?
In which case they are doing what they are supposed to !
When you close a breaker on a loaded circuit,
their will be some small arcing,
if its older and a little bit worn, maybe a bit more arcing.
If this is the case then it's normal.
I suggest you get the model number off the breakers,
and find out for sure if they are normal breakers or AFCI's ?
dmxtothemax is offline   Reply With Quote
Old 02-18-2014, 09:20 PM   #21
From Philadelphia
Rewards Points: 289
Thanks, I'll be trying this out tomorrow.
Just plain 'ol 15 amp breakers, neither AFCI nor GFCI.
Old 02-18-2014, 09:46 PM   #22
Rewards Points: 512
Where are these two breakers physically located in the panel? Are they one on top of the other, or several spaces apart?
Am thinking MWBC.
Installation is the Reverse of Removal.
Old 02-18-2014, 09:50 PM   #23
k_buz's Avatar
Originally Posted by sirsparksalot
Where are these two breakers physically located in the panel? Are they one on top of the other, or several spaces apart? Am thinking MWBC.
They are obviously on opposite phases.
Old 02-18-2014, 09:56 PM   #24
Rewards Points: 512
hmm, still learning, so aren't MWBC on opposite phases?
Old 02-18-2014, 10:37 PM   #25
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
It could be a multiwire branch circuit that is shorting phase to phase. If the circuit was ran with 3 wire modern non metallic (romex) one of the breakers will have a red wire connected to it and one will have a black. Might check that real quick and let us know. Could make things a bit easier to isolate the problem.
I've come across this a few times in my career but it was always the result of a home owner remodel and homeowner DIY wiring.
Also what is your location USA or Canada ?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-19-2014, 05:16 AM   #26
From Philadelphia
Rewards Points: 289
Am thinking MWBC.
One is directly on the of the other.
USA (Philadelphia).
I'll check in the panel for a MWBC in a little bit and get back with my results.
Old 02-19-2014, 07:49 AM   #27
joed's Avatar
Rewards Points: 13,322
Most common cause of this is a split wired receptacle that is replaced and the tab is not cut off. We need to know if there is a red wired involved. If there is then simply start opening receptacles on the circuit and look for a red and black on the same receptacle. If there is then the tab between the screws must be cut only on the hot side(gold screws).
The Following 3 Users Say Thank You to joed For This Useful Post:
hellohello (02-19-2014), joecaption (02-19-2014), Stubbie (02-19-2014)
Old 02-19-2014, 08:18 AM   #28
From Philadelphia
Rewards Points: 289
Awesome Joe, thanks. I will double check on this. And I will keep everyone posted on what I find
Old 02-19-2014, 09:41 AM   #29
From Philadelphia
Rewards Points: 289
I just checked in the panel. No MWBCs. The only two red wires were for two 240-volt circuits. I'm assuming that it's going to be a lot harder to diagnose where the wires are crossed since there is no red wire that would be giving it away in any of the boxes.
Any other tips? If not, here's what I think I'll do, and correct me if you have a simpler idea. I will disconnect the hots from every switch and receptacle. I will test each of those hots twice: once with breaker "A" on and "B" off, and again with breaker "B" on and "A" off. Each time, I will mark with tape where I had power coming in. Hopefully, then, I will be able to identify the box where there are two separate hots coming in.
Sound good? Or do you guys have any other better/simpler ideas?
Old 02-19-2014, 11:11 AM   #30
Not sure if it would help, but google "circuit breaker finder" (can't post links yet...) and you might be able to identify what breaker feeds what outlet. I used one to map my entire house out and found a few things mislabeled.
OR I like the simpler removing outlet covers to see where you might have a double fed outlet.
mowman is offline   Reply With Quote
New electric dryer install trips breaker cortell Electrical 8 08-29-2011 09:09 PM
turning switch off trips breaker nhep Electrical 2 02-08-2011 02:36 PM
How to test that a breaker trips on short BradSG Electrical 13 07-08-2010 08:45 AM
Central Air Trips Breaker RobSmith HVAC 6 08-05-2008 09:06 AM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 04:29 PM
