Is One Brand Of Panel Better Than Another? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-14-2013, 03:55 PM   #16
Settled on the GE, I like the way it turned out. A lot of room at the top and bottom to manipulate wires, went with a whole home surge protector also.
Kodyb is offline   Reply With Quote
Old 01-14-2013, 05:48 PM   #17
Licensed electrician
Rewards Points: 1,018
You cannot have the two grounds in the same lug.
The surge pigtail should be as short as possible.
There might be other issues.
Old 01-14-2013, 06:01 PM   #18
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
On the right side I see 2 neutrals under 1 screw. Not compliant.
Coastal South Carolina
Old 01-14-2013, 06:37 PM   #19
I didn't figure it was, but thats what the old panel had and I'm not even sure where one of them goes & the wire is to tough and short to get into the bar...besides it won't be inspected anyway...
Old 01-14-2013, 07:37 PM   #20
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Did you use a bushing for the conduit coming into the back of the panel? More than one conductor per terminal. What is the black and green wires doing that look like they circle all the way around the panel? Why is there wire with sheathing almost all the way to where it connects?
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 01-14-2013, 08:47 PM   #21
bushing: yes
the wiring circling the panel are the leads running to the stove, I just had a little extra on the end of my rolls so instead of cutting off 18 inches and wasting it I just ran it around there in case I were to ever need it in the future. The other wire in the sheathing on the right side is the dryer leads, just didn't remove the sheathing clear back to reduce clutter since they were going to the lowest breakers...
Sub panel to sub panel feeding tvfd27 Electrical 1 08-21-2012 04:01 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 11:03 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
