Old 01-11-2013, 10:19 AM   #1
Is one brand of panel better than another?
I'm replacing the main 200 amp service panel and was wondering if those you that deal with this on a more regualar basis have a preference in brand. The only big difference I can see is that the Square D QO breakers have the orange trip window. Other than that and the way they hook in I see no difference....
Kodyb is offline   Reply With Quote
Old 01-11-2013, 10:28 AM   #2
If you stick with a Square D you will be able to find the breakers anywhere.
Old 01-11-2013, 11:29 AM   #3
Special User
If you do Square D you want QO, not Homeline. My house has Homeline and Square D doesn't make as many accessories and options for Homeline as it does QO.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 01-11-2013, 12:27 PM   #4
J. V.'s Avatar
Panels are like cars. Everyone has a favorite and usually have a good reason. For me its usually cost. I used GE here at home and it has served me well. It was cheap compared to Square D.
The best panels have a copper buss and cost the most. I guess I recommend the panel with a copper buss and the more spaces the better. JMHO.
Old 01-11-2013, 12:36 PM   #5
Special User
Absolutely. If it physically fits in the space, get a 40-slot panel for sure. That way you don't have to fool around with tandems.
And if for some reason a 40-slot absolutely won't fit, make SURE that the panel you get will accept tandems in ALL slots, not just a couple of them. (I'm glaring at you, Square D .)
Old 01-11-2013, 01:05 PM   #6
Licensed electrician
Many of the panels will only accept tandems in certain slots, if they accept them at all. This is not just a Square D issue.
The internals of a Squared D QO and Homeline are identical. Homeline is just the less expensive line from Square D.
Old 01-11-2013, 01:11 PM   #7
Special User
Quality may be the same, but you can't get Square D interlock kits for certain Homeline panels. Like mine.
Old 01-11-2013, 01:56 PM   #8
At the store(s) where you shop, look at the breakers and panel accessories they carry. And WHICH panel most of those are for.
You might need an extra grounding bar, various sizes of breakers, space saving breakers, GFCI breakers, AFCI breakers, a whole house surge protector which plugs into a double slot, etc. Some stores will carry those items, but for just one brand panel.
It is nice to be able to go to a store and find the accessory you need - not have to order it.
Billy_Bob is offline   Reply With Quote
Old 01-11-2013, 02:14 PM   #9
Trucon01's Avatar
Attached is a pic of my new Square D QO panel / breakers. Another good thing with Square D is you can double tap the breakers, legally.
Basement Demo started Jan 2012:
Bathroom demo started Feb 2013:
Trucon01 is offline   Reply With Quote
Old 01-11-2013, 02:25 PM   #10
Cutler -Hammer CH can accept two conductors also in the smaller ampacities.
Old 01-11-2013, 02:36 PM   #11
Semi-Pro Electro-Geek
The last few panels I've installed (shop, garage, studio, and pool subpanels) have been Eaton (Cutler-Hammer) panels for BR breakers. They're cheap and common, accept tandem and quad breakers, and have enough accessories available. I chose them based on price and availability.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 01-11-2013, 03:42 PM   #12
I've narrowed it down to either Square D QO or GE, leaning toward the GE for the simple fact of cost and it has a copper buss. I like the QO for the fact it has the orange trip indicators but I don't see the benefit of that for twice the cost... even the breakers for the QO are over twice the cost of the GE and even the sqaure D Homeline. GE's whole house surge protector is half the price too. Yep just talked myself into GE... Thanks for all the input guys!!
Old 01-11-2013, 04:18 PM   #13
Licensed Electrical Cont.
Speedy Petey's Avatar
QO also has a copper buss. Even so I cannot justify the added cost, and I HATE QO's neutral bar arrangement.
The Following User Says Thank You to Speedy Petey For This Useful Post:
J. V. (01-12-2013)
Old 01-11-2013, 05:39 PM   #14
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I really like the murray/siemens panels with tin coated copper bus. Even the milbank meter mains I like to install have siemens tin coated cobber bus in them.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 01-11-2013, 06:08 PM   #15
I know what you mean about the neutral bus. My service conductors come in on the side right next to the neutral bus blocking the upper half of the bus.
sgip2000 is offline   Reply With Quote
Sub panel to sub panel feeding tvfd27 Electrical 1 08-21-2012 04:01 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 11:03 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
