One Bathroom Circuit For 5 Bathroom House - Electrical - DIY Chatroom Home Improvement Forum
Old 05-05-2009, 11:30 AM   #1
One bathroom circuit for 5 bathroom house
We just moved into a new home. I have recently discovered that there is only one circuit for all the bathroom outlets. We have two powder baths, but the other three are full baths. Will this cause a problem with the circuit popping too often, especially if more than one hair dryer is used? What is the remedy if the house if fully finished? OUr kids are off to college, but will be returning shortly.
joerunner89 is offline   Reply With Quote
Old 05-05-2009, 11:46 AM   #2
That's the way it was done in the 80's/early 90's. Your outside receps will probably be on this circuit also.
A couple hairdryers will certainly trip this 15 amp circuit. The solution is to bring it current with a new 20 amp circuit to at least one of the bathrooms. While you are at it, consider doing two.
The installation depends on the structure. Attc access? Is the panel accesible? Interior walls?etc.
220/221 is offline   Reply With Quote
Old 05-05-2009, 01:21 PM   #3
It's the cost of an upgrade vs.
using the dryers in other rooms
using the dryer with an extension cord to a different nearby outlet
timesharing hair dryer use
running one dryer on full or two on "low"
etc. . .
The probabilities might be on your side depending on each person's schedule, but if an upgrade costs $X and the inconvenience of resetting breakers is worth $X/100 or $X/50 to you and others then somebody will be doing a lot of resetting.
Old 05-05-2009, 01:28 PM   #4
I'd upgrade to dedicated circuits on 2 of the full baths
Multiple hair dryers will trip the circuit
Old 05-05-2009, 02:00 PM   #5
Was there a "builder's special" on electricians in your neighborhood? Because that's ridiculous. I guess the original electrician came in with the lowest bid, in part, by saving the cost of 4 GFCI receptacles. I'd watch out for other cost cutting measures, such as stab-in connections on all the receptacles, and multi-wire circuits in the kitchen, which can be confusing at first if you've never worked with one.
Question: How recently was code changed to require a dedicated receptacle circuit for each bathroom?
thegonagle is offline   Reply With Quote
Old 05-05-2009, 02:01 PM   #6
Mid 90's??
Old 05-05-2009, 02:41 PM   #7
Licensed Pro
1996 code cycle required GFCI and dedicated circuit for bathroom receptacles, but your area may have adopted this requirement much later.
Old 05-05-2009, 02:49 PM   #8
A dedicated circuit for EACH bathroom?
Still not required as far as I know
The same circuit can feed multiple receptacles in multiple bathrooms, but ONLY bathrooms
Old 05-05-2009, 03:24 PM   #9
Licensed Pro
The 96 code requires a dedicated for each bathroom. The exception for allowing multiple bathrooms (receptacles only) was added later (99 or 02).
Old 05-05-2009, 03:24 PM   #10
Both my upstairs bathrooms receptacles which are back to back rooms are on one circuit and it was built in 2005.
Plumbvoltage is offline   Reply With Quote
Old 05-05-2009, 04:48 PM   #11
Oh. Well, I'm still learnding.
I'm in Minnesota, and I believe they generally adopt current code statewide, late in the year which it is issued. We've been on '08 since late last year.
So, what's the deal, then? Which of these would be code-compliant?
1) Two bathrooms, two receptacles fed from one 20A breaker, and lighting in both fed from other circuits.
2) Two bathrooms, two receptacles fed from separate 20A breakers, and lighting in each bathroom fed from their respective receptacle circuits. (One circuit per bathroom.)
(So 1 is certainly compliant, but personally, I think 2 makes more sense.)
Old 05-05-2009, 04:51 PM   #12
Both meet code
Yup, #2 makes more sense
It boils down to cost in a lot of cases
If bathrooms are back to back it's cheaper to run 1 circuit
I have 3 bathrooms - each one has a dedicated circuit just for outlets
Old 05-06-2009, 11:37 AM   #13
Rewards Points: 756
Actually, the '96 code says:
"Bathroom receptacle outlets shall be supplied by at least one 20-ampere branch circuit. Such circuits shall have no other outlets."
In '96, all the bathroom receptacles could be on ONE circuit. No change thru today.
Mark
busman is offline   Reply With Quote
Tags
bathrooom outlets
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
20 Amp Bathroom Circuit theatretch85 Electrical 3 04-06-2009 09:33 PM
Circuit advice for finishing basement Straightgrain Electrical 16 03-25-2009 09:07 AM
