Once Light Circuit, Multiple Switches - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-26-2012, 08:07 AM   #16
There is a 3way at each man door, for the flourescent lights.
Thanks.
stucker is offline   Reply With Quote
Old 04-26-2012, 08:11 AM   #17
Rewards Points: 2,516
Originally Posted by stucker View Post
At the front door, and the switch box at the front door, I am switching outdoor light above overhead door, outdoor light above door, and a light above the door on the inside. In addition to the 3-way switching the two flourescent lights.
At the back door, a outdoor light above man door, and one on the inside, above door, plus the 3way for the flourescent lights.
Thanks.
So at the back door you need three switches
3-way for the two florescents
SP for the out light above back door
SP for light above the back door on the inside
hammerlane is offline   Reply With Quote
Old 04-26-2012, 08:18 AM   #18
Licensed Pro
To keep the number of wires at a minimum in each box, you should set it up as follows:
For box 1 -
12/2 power in
12/2 power out to box 2
12/3 3way out to box 2
12/2 to light 1 (single pole sw)
12/2 to light 2 (single pole sw)
12/2 to light 3 (single pole sw)
For box 2 -
12/2 power in
12/3 3way in
12/2 to fluorescent lights
12/2 to light 4 (single pole sw)
12/2 to light 5 (single pole sw)
You would find it much easier to do this with 14ga wire.
Old 04-26-2012, 10:56 AM   #19
Which box is power being brought into?
One of the flourescent fixtures? Light box outside of back door? light box outside of front door? light box inside of back door? light box inside of front door? the 4-gang switch box by front door? the 3 gang switch box by back door?
Old 04-26-2012, 11:15 AM   #20
Thanks to all, I have the lighting circuit working now.
Stairway light powered from GFCI circuit? jeh179 Electrical 10 03-23-2011 08:57 AM
Two Switches, an outdoor light, and a wall plug MichaelT Electrical 1 03-06-2011 05:17 PM
Basement lighting circuit - multiple lights and switches, end of circuit cmyk Electrical 2 03-03-2011 02:39 PM
Separating Fan and Light Switches GeauxCajuns82 Electrical 11 08-26-2008 12:03 AM
add a second light to an existing 3 way switch circuit djohns10 Electrical 6 03-02-2007 07:16 PM
