Older Recessed Light Fixtures - Electrical - DIY Chatroom Home Improvement Forum
Old 05-19-2010, 11:29 AM   #1
older recessed light fixtures
I'm trying to determine if the recessed light cans in my ceiling are IC rated. They are at least 10 years old. The model number is CAT71C. I suspect this is an old Halo number.
DocDave is offline   Reply With Quote
Old 05-19-2010, 12:11 PM   #2
Are you sure on that number ?
What size cans (inches) ?
No results from halo:
http://www.haloltg.com/
This is what you searched for:Keyword : CAT71CYour search returned 0 results. Please try again.
also searched for CAT7IC - same result
There is a H71CAT:
http://www.haloltg.com/common/brands...amily&id=13878
Old 05-19-2010, 12:17 PM   #3
Master Electrician
Rewards Points: 3,870
Perhaps that is 7 IC which would indicate an IC can.
H7ICAT is a Halo number.
brric is online now   Reply With Quote
Old 05-19-2010, 06:24 PM   #4
found what I was looking for
I was able to clean off some paint that was covering the labels on the inside of the cans. They are 6" Halos, and they are indeed IC rated.
Please recommend a small recessed light for accent/gen use RickDel Electrical 7 03-27-2012 01:23 PM
Normal light fixtures with suspended ceiling? Scott99999 Electrical 9 09-02-2010 04:44 PM
Wire recessed light from a 3 prong receptacle? prc114 Electrical 9 12-22-2009 09:29 AM
Trouble Inserting Recessed Light Into Ceiling Cavity PotLightGirl Electrical 7 11-02-2009 01:15 PM
Recessed light wire size jizzle Electrical 6 12-03-2008 09:56 AM
