Old 10-28-2012, 11:52 AM   #1
Older portable generator has no L14-30 receptacle
Older 5000w generator only has two 120v 5-20R and two 240v 6-20R plugs. How can I connect this generator to a transfer switch that uses a L14-30 connector?
Roy14 is offline   Reply With Quote
Old 10-28-2012, 12:36 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
See Generator to panel wiring
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 10-28-2012, 04:41 PM   #3
Master Electrician
To be code compliant, you can't.
brric is offline   Reply With Quote
Isolated Ground Receptacle Bocolo Electrical 40 01-23-2012 03:44 PM
continuous load anesthes Electrical 50 01-14-2012 01:35 PM
Replacing old receptacle (PICS) picflight Electrical 14 10-28-2011 08:05 AM
Using a multimeter to test a 50 amp receptacle WendyS Electrical 12 01-22-2010 09:10 AM
Wiring timer from receptacle intotao Electrical 7 01-21-2009 09:57 AM
