Older Cottage - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2010, 07:09 PM   #1
Older cottage
Just bought a older cottage and started to replace some receptecles. Went to switch the fridge plug and noticed it had four wires attached. Green ,white ,red and black. Followed it down to the old panel nothing else is attached to this line. No problems hooking up the green,white and black wires but unsure what to do with the red. They had this hooked to the hot side of the plug beside the black but with the connecting bar removed.
alphamale1 is offline   Reply With Quote
Old 01-02-2010, 07:20 PM   #2
Licensed electrician
Rewards Points: 1,872
Sounds like a duplex being served by 2 circuits sharing the neutral connection. This is commonly called a multi-wire branch circuit. There should be 2 breakers tied together to shut off the power to this receptacle.
Old 01-02-2010, 09:00 PM   #3
Thanks Jim
Should I go ahead and just rewire the new plug the same way? Is this safe ? or is there a better way of rewiring this plug .
Old 01-02-2010, 09:25 PM   #4
You need to break off the tab on the hot side of the receptacle
This places each plug on a different circuit
Where are you located ?
Where is the outlet located ?
Old 01-02-2010, 09:31 PM   #5
joed's Avatar
Rewards Points: 13,712
Sounds like a split wired receptacle. Standard set in Canadian kitchens. Break the tab onthe gold screw side and reconnect as it was.
Old 01-02-2010, 09:59 PM   #6
Lightbulb
It is also a stingy way of providing minimum service by a landlord who cares little for the comfort of the tenants. BTW. what is the purpose of a MWBC on a refrigerator receptacle, as (I believe) the OP mentioned.
spark plug is offline   Reply With Quote
Old 01-02-2010, 10:05 PM   #7
Well most fridge outlets are behind the fridge
But I have been in plenty of Apts & older houses where the outlet is on the counter & the fridge plug/cord comes across to plug in
And one Apt they had a surge strip plugged into the fridge outlet to provide more plugs for kitchen use
Old 01-03-2010, 12:13 AM   #8
Thanks for your responses.
I live in Ontario Canada and the plug in question used to be above a kitchen counter top but I since moved that counter top and I am in the process of installing the fridge in that space. The second problem with this plug is that they didn't have the ground connected properly so when I would plug in my tester it showed that the connection was good but it was not grounded. I was going to install a grounding pigtail inside the receptacle box to see if this worked what do you think?
Old 01-03-2010, 12:24 AM   #9
Question
It would only work if the box itself is grounded as, for example either being attached to conduit or BX, (Which I doubt) or, having the bare wire of Romex (NM cable) (called Lumex, in Canada. Having lived there in the past.) attached to the box and the other end connected to Ground in the Panel? (antique)!
Old 01-03-2010, 12:31 AM   #10
Exclamation
Having resided in the past (1971) in Montreal, Canada, this is exactly how the "upgraded" wiring in our kitchen looked. A MWBC outlet above the counter and no dedicated outlet for the refrigerator! All of that connected to a nice, modern Fuse box!
Old 01-03-2010, 09:55 AM   #11
joed's Avatar
15 amp MWBC counter receptacles is a standard installation in Ontario for kitchen counters. Fridges now have to be on a dedicated circuit under the current code.
older furnace trouble dags6555 HVAC 1 12-10-2009 06:19 PM
Outlet With Swith and Older (White, Black, Red) Wire CaptChaos Electrical 18 09-14-2009 11:17 PM
Older GE Fridge no Ice WorldOfJohnboy Appliances 3 09-10-2009 07:39 PM
Question about replacing load center in older house speedster1 Electrical 5 05-14-2009 07:55 AM
Adding a phone line to an older connect point cramsmith General DIY Discussions 3 11-23-2005 11:35 AM
