An Older Challanger Main Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 11-16-2012, 08:31 AM   #1
An older Challanger Main Panel
I have a 200 Amp Challanger main panel, installed in my house in 1996. I've added a few breakers and ran some wires into the panel over the years and seem to have misplaced the screws that hold the panel cover over the breakers and wires. Everything is exposed, which is not a safe condition.
Any suggestions on how to tell what size screw I need for the panel? I'm assuming SAE and not metric, but have tried 3 or 4 different sizes with no luck. Not sure what to use to determine the correct size or if there is anyway to find a reference for this somewhere.
Thanks.
OKDrew63 is offline   Reply With Quote
Old 11-16-2012, 10:19 AM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Thanks.
Try ground screws.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 11-19-2012, 09:45 AM   #3
Just a ground screw from an outlet or switch? Those don't fit.
Old 11-19-2012, 10:40 AM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 420
I use sheet metal screws with the tips filed down.
Sometimes you need washers.
Old 11-19-2012, 09:29 PM   #5
electures's Avatar
Box ground screw.
Old 11-19-2012, 11:09 PM   #6
Rewards Points: 13,458
My local hardware store has them, Lowes HD, any electrical supply.
My hardware store has them in the fastner area with those pull out bins.
Says elecrical on the end of the bin.
The box stores had them in the same area where the panels were sold last time looked.
There a fine thread machine screw.
Old 11-20-2012, 10:58 AM   #7
Julius793's Avatar
10-32s usually work
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 11-20-2012, 01:20 PM   #8
electures's Avatar
Originally Posted by Julius793 View Post
10-32s usually work
Ground screws are 10-32 thread.
Main Electric Panel Help Redrum Ninja Electrical 13 10-22-2011 07:28 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Main panel or sub panel? tbeaulieu Electrical 5 04-07-2010 11:58 AM
Main Panel / Service Upgrades gbe Electrical 12 11-06-2009 11:20 PM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 08:18 PM
