Old Work, And Securing Romex - Electrical - DIY Chatroom Home Improvement Forum
Old 11-27-2011, 11:56 PM   #1
Rewards Points: 43
Old Work, and Securing Romex
From what I can remember of code, it requires that NM cable be secured within 12 inches of a junction box.
How do you typically fulfill this requirement for old work installations? Are you forced to cut the drywall, larger than needed for the old work box in order to get a stapler in the wall to secure the cable or is there an exception in the code I am missing somewhere for old work?
dcapone is offline   Reply With Quote
Old 11-28-2011, 12:02 AM   #2
" Euro " electrician
frenchelectrican's Avatar
There is extempt for old work cut in boxes and you do not need staples in finshed wall on old work set up.
And majorty of the old work box will have interal clamp so that is allready dealt with it { few don't have it so you will have to get romex clamp espcally this is true with most of metal old work box but few do have interal clamp as well }
But once you get into exposed area or unfinshed area or rough in then it have to be staple it down per NEC codé requirement.
Merci,
Marc
Old 11-28-2011, 06:09 AM   #3
Rewards Points: 1,512
Even if you have to cut a hole in the wall in the middle of nowhere to make it easier to fish the cable, you do not have to make the hole big enough to reach in and staple the cable.
Securing Elevated Deck to House Earnie Building & Construction 18 08-25-2011 07:46 AM
Securing CSST gas line NowItsShowtime Plumbing 10 04-29-2011 09:15 AM
preferred outlet box type & work order mlupa Electrical 17 12-07-2008 02:54 PM
Securing subfloor over a concrete pad ktulu05 Flooring 4 06-18-2008 07:19 AM
Will this work and remain watertight? End Grain Plumbing 7 01-21-2008 10:23 AM
