In Old Work, How Do You Add A 50 Lb Light Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-28-2015, 08:01 PM   #1
Rewards Points: 342
Question
In Old work, how do you add a 50 lb light box?
enochian is offline   Reply With Quote
Old 07-28-2015, 08:36 PM   #2
dmxtothemax's Avatar
Rewards Points: 5,608
" In old work "
What does this mean ?
dmxtothemax is offline   Reply With Quote
Old 07-28-2015, 08:39 PM   #3
Rewards Points: 342
drywall is up.
Old 07-28-2015, 08:40 PM   #4
Go buy an old work fan box rated for 50 lbs. It will have a bar with brackets on the sides. As you spin the bar the brackets will move outward and bite into the ceiling joists.
eric626 is offline   Reply With Quote
Old 07-28-2015, 09:16 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
You have a light box that weighs 50 pounds???
The Following User Says Thank You to Speedy Petey For This Useful Post:
InPhase277 (07-29-2015)
Old 07-28-2015, 09:37 PM   #6
Rewards Points: 342
A lightbox that can support 50 lbs.
Old 07-28-2015, 09:40 PM   #7
Rewards Points: 342
This was my thinking. I just wanted to see if I was missing something.
Old 07-29-2015, 05:40 AM   #8
I know. I was being facetious.
It is kind of hard to accurately answer a question like this considering the only detail we know is the support weight of the box.
A properly mounted fan box will support 50#.
Old 07-29-2015, 11:04 AM   #9
Rewards Points: 342
What if you are not sure closet underneath stairs has joists?
Old 07-29-2015, 11:10 AM   #10
Rewards Points: 168
it might be better if you post your intentions of use of this box,
what are you intending to mount/install to this box?
Mikey1 is offline   Reply With Quote
Old 07-29-2015, 11:21 AM   #11
Rewards Points: 342
30 lb chandelier
Old 07-29-2015, 12:39 PM   #12
Rewards Points: 194
30 lb chandelier
In a closet?
billtech is offline   Reply With Quote
Old 07-29-2015, 12:49 PM   #13
Licensed electrician
Rewards Points: 1,876
The OP never mentioned a closet.
Old 07-29-2015, 12:53 PM   #14
Rewards Points: 1,654
I am thinking perhaps he has a multi-story setup, where the downstairs dining room needs a 30# chandelier but the ceiling where it is to be mounted is actually a closed in closet space underneath a set of stairs that goes from the second to the third floor.
If that's the case I would just add bracing in that closet to build whatever you need to support that chandelier.
miamicuse is offline   Reply With Quote
Old 07-29-2015, 01:56 PM   #15
Rewards Points: 194
Talking
See #9. That was what piqued my curiosity.
confusion with track light stephenbishop Electrical 7 03-10-2012 01:37 PM
Ceiling fan light fixture doesn't work c4hfam Electrical 9 03-05-2011 01:01 PM
Light fixture in ceiling fan won't work. Tested DIYself Electrical 7 11-28-2010 11:52 AM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
ANOTHER ceiling fan light fixture doesn't work bandguy Electrical 8 06-13-2007 08:40 AM
