Old 05-11-2010, 03:12 PM   #1
Just call me Andrew
Are old-work ceiling fan boxes safe?
My parents want a ceiling fan in place of their current light in the bedroom. Attic space is above, but it's floored. If it's just as safe, I'll use an old work box instead of cutting a hole in the plywood attic floor.
Also - is there an easy way to tell if my current bedroom fan is using a fan-rated box? I don't trust that the previous homeowners did it right at all...
Thoughts?
Andrew
secutanudu is online now   Reply With Quote
Old 05-11-2010, 03:17 PM   #2
Licensed electrician
SmartBox and Arlington both have old work fan rated boxes that will secure to the joists.
The fan rated boxes should have a label that states "Acceptable for fan support" or "Fan rated box".
Old 05-11-2010, 03:21 PM   #3
Just call me Andrew
The ones i've seen have tubes inside each other that you unscrew to push into neighboring joists - I get how they work, just not sure if they are really OK to use (despite their fan rating), or if I should put in the extra time and put an old-work box in.
Andrew
Old 05-11-2010, 03:25 PM   #4
Never had a problem with the screw out expansion brackets. Just don't go out too far and crack the drywall or plaster.
secutanudu (05-11-2010)
Old 05-11-2010, 06:49 PM   #5
Electrical Contractor
I sure hope so!
I have a couple in my house, and have installed many of them over the years.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
The Following User Says Thank You to jbfan For This Useful Post:
Old 05-11-2010, 08:06 PM   #6
Just call me Andrew
Thanks!
Andrew
need ideas for work shop ceiling material vttree Remodeling 8 12-15-2008 07:28 AM
old work boxes handifoot Electrical 7 12-12-2008 04:41 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 09:16 AM
halogen lights fitted into a polystyrene ceiling - safe? jono_wales Electrical 1 03-07-2005 03:52 PM
