Old 03-25-2012, 11:54 AM   #1
Old Work boxes - wiring management in walls
Hello,
When installing old work boxes, how are the cables that are run to the box secured/attached inside the wall? I have some 4 gang boxes with 6 cables running to them. Currently they just run down from the top plate to the cutout in the wall with no attachment.
What will an inspector want to see?
Thanks!
Jaxx is offline   Reply With Quote
Old 03-25-2012, 11:57 AM   #2
Licensed electrician
Cables that are fished in closed walls are not required to be secured to the studs.
The boxes will have clamps for the cables.
Old 03-25-2012, 12:01 PM   #3
Code05's Avatar
Are these blue cut in boxes? If so, only one cable per clamp.
Code05 is offline   Reply With Quote
Old 03-25-2012, 12:03 PM   #4
DIY Enthusiast
sublime2's Avatar
The tabs in the back of the old work box r there to hold the wires. Just break the one tab on them to push wire through the box. Do not remove the tab completely.
sublime2 is offline   Reply With Quote
Old 03-25-2012, 12:04 PM   #5
This would apply to all plastic boxes, not just blue ones.
Old 03-25-2012, 12:04 PM   #6
Yes, cut in boxes, but white. They do have the plastic clamps.
No attachment required, that is great (for me as the installer :-) )
Old 03-25-2012, 12:07 PM   #7
Code05's Avatar
Ya got me. Nice catch.
Old 03-25-2012, 12:11 PM   #8
You had to know I was going to point that out. JK D.
Old 03-25-2012, 04:05 PM   #9
Code05's Avatar
Of course, I would have also.
Wiring walls low voltage training books etc LewisO General Discussion 1 03-05-2011 02:02 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
wiring outlet boxes, steel or plastic? DangerMouse Electrical 17 07-20-2008 01:05 PM
Work boxes? sandyman720 Electrical 5 06-01-2007 03:33 PM
Required support for wiring in walls? leonsphinx Electrical 5 02-23-2007 07:25 AM
