Old Work Box Templates - Electrical - DIY Chatroom Home Improvement Forum
Old 04-20-2008, 11:49 AM   #1
Rewards Points: 121
Old work box templates
Does anyone have any printable templates or links to such online for installing carlon single and dual gang old work boxes
thanks
scrupul0us is offline   Reply With Quote
Old 05-09-2008, 12:19 PM   #2
Old work box templates at www.cutzout.com
You might want to go to www.cutzout.com and see if they have any printable templates. I know that they have templates that guide spiral saws to cut drywall for single gang and double gang boxes, but don't remember whether they offered printable templates. I have attached a picture of their single gang template. It looks as though it could be used to draw the outline for a box.
an old handyman
Old work box templates-cutzout-20single-20gang-20installation-20template-201.jpg
oldhandyman is offline   Reply With Quote
Old 05-09-2008, 04:35 PM   #3
Rewards Points: 121
no luck with printables, but thats some AWESOME stuff right there... thanks for the info
Old 05-09-2008, 05:33 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
I am really not trying to be a jerk about this, but if you need one of those tools to cut out a rectangular hole in sheetrock you probably shouldn't even be using power tools in the first place.
scrupul0us, there is no secret trick to marking out boxes. Just hold the opening of the box against the wall and mark around the edges.
If there is casting flash in places you should break it away so you have an accurate marking.
The Following User Says Thank You to Speedy Petey For This Useful Post:
joecaption (01-15-2016)
Old 05-09-2008, 06:42 PM   #5
Petey, you probably put more boxes in, in a day then I will in a life time, but placing the opening of the box on the wall and outlining it, is what gives me the problem, for new work, I use the plastic box with the ears that extend when turning the screw., If I outline the front, the box goes right thru so I start small and keep checking, and yes, thank goodness I'm not getting paid by the hour for it.
DUDE! is offline   Reply With Quote
Old 05-09-2008, 07:03 PM   #6
I guess I should have said mark around the box edges, and not the ears that stick out.
Old 05-09-2008, 10:55 PM   #7
electrical contractor
Rewards Points: 150
Carlon used to put a paper template in the box with their old work boxes, look in the box where ever you buy them and see if they still do put them in. You could also make your own out of poster board or cardboard, take the time to do it right once, then just trace it out on the wall.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 01-15-2016, 10:06 AM   #8
Rewards Points: 18
Here's one for the round B618R.
http://www.homedepot.com/catalog/pdf...0fec3952e0.pdf
Tonyski54 is offline   Reply With Quote
Old 01-15-2016, 10:45 AM   #9
Rewards Points: 516
At one point, I had a plastic template that had a level built into it. It sucked. I used it twice and didn't like the the results. The best method I've found is the way Speedy described. What are you using to cut the drywall? I had a helper who would walk all the way out to the van, grab a multi tool, look for a battery, look for a blade, drive me nuts, when all he needed was the keyhole saw sitting right in front of him.
Arrow3030 is offline   Reply With Quote
Old 01-15-2016, 02:01 PM   #10
Originally Posted by Tonyski54 View Post
Dayum!!
Nearly and 8 YEAR thread resurrection!! Pretty close to a record I think.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
jbfan (01-15-2016), Jim Port (01-15-2016)
Old 01-15-2016, 03:24 PM   #11
Rewards Points: 516
Got me good lol. I saw speedy and figured it was new
The Following User Says Thank You to Arrow3030 For This Useful Post:
MT Stringer (01-15-2016)
Old 01-15-2016, 06:36 PM   #12
Rewards Points: 3,781
UH! You trace the back of the box, not the front!
Actually I traced it one time onto a small piece of Luan which I keep in my electric tool box.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 01-15-2016, 07:12 PM   #13
Rewards Points: 516
I traced the origins of the box all the way to Hecho Mexico wherever that is.
The Following 3 Users Say Thank You to Arrow3030 For This Useful Post:
Colbyt (01-16-2016), MT Stringer (01-15-2016), Speedy Petey (01-16-2016)
HVAC contractor ripoff! sekntonone HVAC 8 04-05-2008 07:15 AM
Need help with permit/city got a Stop Work Order. amdspitfire General DIY Discussions 39 02-07-2008 02:45 PM
photo cell lights thst only work sometimes... kemerick Electrical 10 11-10-2007 11:29 AM
is this bad tiling work? garrick Flooring 17 09-27-2006 12:30 AM
