"Old Work" Box Mounting Nitpicking - Electrical - DIY Chatroom Home Improvement Forum
Old 04-02-2008, 10:04 PM   #1
Learning by Doing
Leah Frances's Avatar
"Old Work" Box mounting nitpicking
I'm installing a 2 gang metal "old work" box in my remodel. Long story short - I had to tear out the wall surface (fiberboard) I'm going to replace it with drywall.
Do I have to leave it open for my rough-in inspection? Or do I just throw up the new drywall since technically I fished the wire before I tore the old stuff out (how's that for a PITA). If I should leave it open for inspection; how do I mount the "old work" box for the proper depth? Do I just bite the bullet and get a new work box with a bracket?
So, I am a can't see the forest for the trees kind of gal. But, I can't figure out how I want to go with this. And I can't stop obsessing about it.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-02-2008, 10:27 PM   #2
Licensed electrician
Rewards Points: 1,258
Since you removed the finish, leave it open for your rough-in inspection. Staple the wire to the studs too.
Use a new work box with a bracket or try one of these
Available at electrical supply houses. Try ED near the Walmart.
http://www.aifittings.com/whnew78.htm
Old 04-02-2008, 10:45 PM   #3
Custom Cabinet Maker
Finally a really nice box
skymaster is offline   Reply With Quote
Ceiling Fan mounting Big Bill General DIY Discussions 8 02-07-2010 09:07 PM
Mounting Ceiling Fan to Exposed Beam zero1niner Electrical 7 05-05-2009 12:41 PM
Mounting a Punching Bag reingam@hotmail.com Building & Construction 4 10-07-2007 08:37 PM
Mounting corner Bead KUIPORNG Remodeling 7 01-04-2007 09:20 AM
Plastic "Old Work" wall box - Grounding Screws? strohs19 Electrical 4 01-14-2006 07:46 PM
