Old Wiring, New Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 11-23-2008, 10:39 AM   #1
Question
Hi all,
To start off with, let's get this out in the open.. I'm pretty inexperienced with electrical work.
I have to replace an outlet in my 1930's house. When I took the old outlet off, the wiring didn't look like what I was expecting. I was hoping to see a black, white, & ground wire, but instead I just just have 2 black wires. (see attached picture)
Please help me understand how I can differentiate which one is hot and which one is neutral. Also, what should I do about not having any ground wire. Does it matter what kind of plug I use? (Right now I have a 15A 3-prong plug)
Thanks in advance for the help!
-Andrew
atkearns is offline   Reply With Quote
Old 11-23-2008, 10:43 AM   #2
Forgot to attach the picture. I uploaded it here:
http://www.diychatroom.com/album.php...pictureid=1132
Old 11-23-2008, 11:54 AM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Do you have a voltage tester? One like this would be fine..... Your wiring appears to be armored flex either bx or ac which will likely be sufficient for a ground. Test each wire individually to the metal box. The wire that lights the tester is your hot wire. If neither wire lights the tester then you do not have a good ground and we will try something else.
Old 11-23-2008, 11:56 AM   #4
It looks like the one on the left is the white.
jerryh3 is offline   Reply With Quote
Old 11-23-2008, 12:22 PM   #5
Originally Posted by Stubbie View Post
And with this (neon?) tester, if they both light it try a 4w bulb for a tester (assuming there is no 240v on these wires).
Old 11-23-2008, 12:56 PM   #6
Thanks for the quick response.
I don't have a voltage tester like you showed, but I do happen to have a Circuit Alrert GVD-504A (http://www.diychatroom.com/picture.p...pictureid=1133). It beeps & lights up next to the wire on the right. So that would mean it's hot, correct?
Now, what about grounding? Is it OK to just to just hook up these 2 wires w/out a separate grounding wire?
Old 11-23-2008, 01:03 PM   #7
Rewards Points: 150
I have one of those testers you show and I think they are difficult to determine a hot wire from a non hot when they're in close proximity. As long as you have the wires exposed, I would get the other type suggested above and use it. They're pretty inexpensive
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 11-23-2008, 01:13 PM   #8
Hmm.. well I just went back & tested again, it's obvious which one is hot. I spread the 2 wires apart.. It definitely indicates the right wire, & nothing on the left.
So my only question is about if it's OK to install w/out a ground wire. I read on 1 site that you should use a GFI plug if there's no ground wire. Can anyone corfirm/deny this?
Old 11-23-2008, 01:27 PM   #9
Licensed Pro
You can replace with another two prong receptacle or a GFCI receptacle. If using the GFCI, you must label the receptacle with the "no equipment ground" label found in the GFCI package.
Old 11-23-2008, 01:33 PM   #10
GFI is allowed by code and is the only way to install 3 prongs on 2 wire circuits, unless you have bx with a bonding strip...but that is usually found in 1955-1965 homes...
rgsgww is offline   Reply With Quote
wiring a dedicated switch to a outlet Michel Electrical 2 09-18-2008 07:25 PM
Wiring a new outlet advice kennykenny Electrical 19 08-29-2008 11:54 AM
Wiring Sequence on Adding a New Outlet kennykenny Electrical 9 06-09-2008 03:06 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
Wiring an outlet in the garden wackerjr Electrical 8 05-28-2006 09:18 AM
