-   -   Old Wiring, New Outlet (http://www.diychatroom.com/f18/old-wiring-new-outlet-32448/)
atkearns 11-23-2008 09:39 AM
Hi all,
To start off with, let's get this out in the open.. I'm pretty inexperienced with electrical work.
I have to replace an outlet in my 1930's house. When I took the old outlet off, the wiring didn't look like what I was expecting. I was hoping to see a black, white, & ground wire, but instead I just just have 2 black wires. (see attached picture)
Please help me understand how I can differentiate which one is hot and which one is neutral. Also, what should I do about not having any ground wire. Does it matter what kind of plug I use? (Right now I have a 15A 3-prong plug)
Thanks in advance for the help!
-Andrew
atkearns 11-23-2008 09:43 AM
Forgot to attach the picture. I uploaded it here:
http://www.diychatroom.com/album.php...pictureid=1132
Stubbie 11-23-2008 10:54 AM
Do you have a voltage tester? One like this would be fine..... Your wiring appears to be armored flex either bx or ac which will likely be sufficient for a ground. Test each wire individually to the metal box. The wire that lights the tester is your hot wire. If neither wire lights the tester then you do not have a good ground and we will try something else.
http://www.telonixshop.com/store/images/61-503.jpg
jerryh3 11-23-2008 10:56 AM
It looks like the one on the left is the white.
Yoyizit 11-23-2008 11:22 AM
Originally Posted by Stubbie (Post 188981)
And with this (neon?) tester, if they both light it try a 4w bulb for a tester (assuming there is no 240v on these wires).
atkearns 11-23-2008 11:56 AM
Thanks for the quick response.
I don't have a voltage tester like you showed, but I do happen to have a Circuit Alrert GVD-504A (http://www.diychatroom.com/picture.p...pictureid=1133). It beeps & lights up next to the wire on the right. So that would mean it's hot, correct?
Now, what about grounding? Is it OK to just to just hook up these 2 wires w/out a separate grounding wire?
handifoot 11-23-2008 12:03 PM
I have one of those testers you show and I think they are difficult to determine a hot wire from a non hot when they're in close proximity. As long as you have the wires exposed, I would get the other type suggested above and use it. They're pretty inexpensive
atkearns 11-23-2008 12:13 PM
Hmm.. well I just went back & tested again, it's obvious which one is hot. I spread the 2 wires apart.. It definitely indicates the right wire, & nothing on the left.
So my only question is about if it's OK to install w/out a ground wire. I read on 1 site that you should use a GFI plug if there's no ground wire. Can anyone corfirm/deny this?
HouseHelper 11-23-2008 12:27 PM
You can replace with another two prong receptacle or a GFCI receptacle. If using the GFCI, you must label the receptacle with the "no equipment ground" label found in the GFCI package.
rgsgww 11-23-2008 12:33 PM
GFI is allowed by code and is the only way to install 3 prongs on 2 wire circuits, unless you have bx with a bonding strip...but that is usually found in 1955-1965 homes...
