Old Wiring In Kitchen - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2010, 10:57 AM   #1
Old wiring in kitchen
Good morning,
I am new to the forums and this is my first post. My home was built in 1965 and has older wiring in it. My kitchen has grounded receptacles installed but no ground wire is present. I checked the wiring at the main panel and oddly enough a ground wire is present for the circuit. It appears someone must have clipped the ground wire at the outlet box.
I would like to have some of the outlets grounded. Should I rip out all the old wiring and replace it or just add a new circuit?
Thanks!
donnek is offline   Reply With Quote
Old 11-15-2010, 11:28 AM   #2
joed's Avatar
Rewards Points: 11,598
You need to inspect the existing cable. The ground might be there. Sometimes they wrapped it around the cable and put it under the clamp. You just need to fish it out into the box.
Kitchen receptacles should be GFCI by current code. Even if the ground is not present GFCI is a valid replacement for ungrounded receptacles.
Old 11-15-2010, 12:20 PM   #3
Thanks joed for the response. I previously removed the cable clamp in the box and could not see a ground wire which led me to the conclusion that the wire had been cut. If I install a GFCI can the other downstream outlets remain 3 prong? Will a GFCI breaker do the same? Are there any concerns using appliances with a grounding plug on the circuit? Thanks again.
Old 11-15-2010, 02:52 PM   #4
joed's Avatar
One receptacle can protect downstream receptacles id connected to the LOAD terminals. REceptacles are cheaper than breakers. I would use a GFCI receptacle. It is also easier to find and get to if it trips.
Old 11-15-2010, 03:41 PM   #5
Thanks for the reply. My only concern with the GFCI receptacle is the size of the box. I don't know if I could get it to fit.
Old 11-16-2010, 12:24 PM   #6
Can anyone tell me if there are any concerns using grounded appliances on an ungrounded kitchen circuit protected by a GFCI?
Old 11-16-2010, 01:02 PM   #7
Craftsman
Donnek, describe the ground you found at the panel. Some older homes were wired with two wire romex but had a separate ground wire (#12 or #14) run with the romex and attached to the outside of the device boxes in the kitchen and laundry circuits. Did you test from hot to the box or use a plug-in tester to see if the box is grounded.
Superrick is offline   Reply With Quote
Old 11-16-2010, 02:08 PM   #8
The ground wire at the panel appears to be a smaller wire, possible #16? I tested from hot to the metal box at each outlet location.
Old 11-16-2010, 02:47 PM   #9
Rewards Points: 256
Ther are no concerns using appliaces with 3 prong style grounded plugs into a gfci protected ungrounded outlet.
If everything functions properly the ground wire never gets used.
It is there to reduce the shock severity if something goes awry.
Gfci's are an acceptable alternative to grounding for retrofits only.
They offer shock protection in a different method.
Long story short: the ground isn't needed to make an appliance work its there for your protection
michaelcherr is offline   Reply With Quote
Kitchen Wiring Requirements SS396 Electrical 24 02-07-2011 11:00 AM
Using same tile for bathroom and kitchen too Matchy-Matchy? Jeanene Interior Decorating 10 03-29-2010 01:38 AM
So I'm Thinking about Doing Renovations on My Kitchen Jim.Lee Kitchen & Bath Remodeling 6 03-15-2010 08:53 PM
Wiring inside kitchen island? vsheetz Electrical 14 05-12-2009 02:49 PM
Kitchen Wiring Questions Chazbe Electrical 22 04-11-2008 05:06 PM
