Old 01-01-2013, 03:57 PM   #1
Old wiring done wrong?
So I was replacing an old light fixture with a newer one, when I noticed that the light was wired with 14ga wire, but is on a 20amp breaker.
Upon checking a few outlets, it seems that the entire upstairs of my house (which is all on 1 20amp breaker, just 2 rooms) is wired with 14ga. Is this a big problem? I thought you had to use 12ga on a 20amp breaker?
FYI the house is about 50 years old.
Thanks!
Randomnist is offline   Reply With Quote
Old 01-01-2013, 03:59 PM   #2
Licensed Electrician
k_buz's Avatar
Yes, the breaker should be changed to a 15A or the wiring should be changed to 12 AWG. Changing the breaker is easier.
Location...Location...Location
Old 01-01-2013, 04:17 PM   #3
That was probably someone's way of fixing a constantly tripping 15 amp breaker - install a larger breaker! (Dangerous and a good way to burn your house down!)
And you may find the new 15 amp breaker trips. The easiest way to properly fix that is to run new wires (12 ga. / 20 amp) to power hogs. Like a refrigerator, plug for vacuum, bathroom, etc. (Instead of rewiring everything.)
Another more complicated fix, if there are junction boxes for wires going to various rooms in the attic, is to split the circuit and then use several 15 amp breakers for parts of the circuit. (Break the one large circuit into several small circuits. Run new wires from the panel to those points in the attic.)
Billy_Bob is offline   Reply With Quote
please tell me whats wrong with my wiring here c miller Electrical 11 09-17-2012 03:27 PM
Knob & Tube Wiring? cbzdel Electrical 8 08-17-2012 07:33 AM
Charred / melted wall receptacle, AL wiring in house creamaster Electrical 17 12-04-2009 05:47 PM
Knob and Tube wiring. bronco2 Electrical 8 10-03-2009 01:36 PM
Sunset Basic Home Wiring cover is wrong? CareBear Electrical 3 09-03-2009 11:31 AM
