Old Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 03-30-2009, 04:05 PM   #1
old wiring
Hello,
until I can upgrade my wiring I have a question...I have old cloth type wiring with no ground and my question is all my outlets are old school with only two prongs can I upgrade the outlets and not having the ground wire hurt any of my fixtures and washer/dryer?
Z
zombie911 is offline   Reply With Quote
Old 03-30-2009, 04:43 PM   #2
You could put GFCI outlets, you would only need one at the beginning of the circuit and all the outlets connected to the load side of the GFCI will be protected, you should also place the "No Equipment Ground" label on the outlets that come after the GFCI.
Sliver is offline   Reply With Quote
Old 03-31-2009, 07:24 AM   #3
Computer type equipment should have a ground. Like lcd tvs, etc. But yes, you can install gfcis to use three prongs.
rgsgww is offline   Reply With Quote
Old 03-31-2009, 08:56 AM   #4
Thanks for the response......This is an old cinder block house so all outlets run from a j-box in the attic down wall seperatly,can I put in some type of gfci breaker and then just change outlets with regular 15a?
Old 03-31-2009, 09:09 AM   #5
Rewards Points: 2,350
Cinder blocks huh? Is the wiring in conduit?
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
