Old Wire, What Is It? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-06-2009, 11:14 AM   #1
Rewards Points: 894
Old wire, what is it?
Hello;
I am doing a little rewiring of the old BX in my home, and cutting this old wire, it looks like aluminum, but feels like copper when bent.
I cut off a bit, and scraped it down to see what is below the aluminum color on the surface, and found copper.
This wire is cloth covered rubber insulation. Is this zinc plated, tinned, or what?
Ultrarunner2017 is offline   Reply With Quote
Old 01-06-2009, 11:22 AM   #2
I've seen the old copper that looks like aluminum.
I'm not a rocket scientist, I don't know what the reason is.
220/221 is offline   Reply With Quote
Old 01-06-2009, 11:52 AM   #3
Rewards Points: 266
Most old rubber covered wires are tinned with solder because the sulfur used in the rubber making process would corrode the bare copper easily. If I remember correctly, it was is only a problem during manufacture.
Best I have.
junkcollector is offline   Reply With Quote
Old 01-06-2009, 01:14 PM   #4
Rewards Points: 894
Best I have.
Thanks for the reply;
Solder makes a lot of sense, since it doesn't tarnish, and is a good conductor of electricity, as well as a good buffer as you indicated.
New Stove, old wires - 2 wire vs 3 wire DIYGST Electrical 22 03-02-2009 04:13 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
