Old White Rodgers Thermostat - Electrical - DIY Chatroom Home Improvement Forum
Old 12-31-2010, 01:57 PM   #1
old White Rodgers thermostat
I have an old White Rodgers thermostat in my apartment. I took the cover off the front, what does the #'s inside mean? (i.e .15, .25,.5o etc) How can I set this to get my apartment warm?:(
TraciL is offline   Reply With Quote
Old 12-31-2010, 02:09 PM   #2
I=E/R
a7ecorsair's Avatar
Those numbers are the temperature difference for turning the heat on and off. Changing this setting will not make your apartment warmer. Do you know what type of heating system is in this apartment? Do you have your own furnace?
a7ecorsair is offline   Reply With Quote
Can a single stage thermostat used on 2 stage heat pump? deerhunter HVAC 10 11-06-2010 11:43 PM
Thermostat wiring jetmanaz HVAC 1 08-09-2009 07:13 PM
Thermostat help needed rjkleiner HVAC 1 08-05-2009 06:46 AM
Thermostat will not follow commands beacu Electrical 5 01-06-2009 10:20 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
