Old Well Pipe No Longer Connected To Plumbing - Electrical - DIY Chatroom Home Improvement Forum
Old 06-23-2014, 05:43 PM   #1
Rewards Points: 127
Old well pipe no longer connected to plumbing
My house in Northern Minnesota used to be fed by a well with steel pipe connecting the well to all water faucets. Now that well is defunct. The house is now fed by a well some distance away and connected to the house by PVC pipe. There is a ground line running from the main panel to the old well pipe, but the old well pipe is no longer connected to the house plumbing.
Do I need to do add any new ground runs be be safe and compliant?
Thanks in advance.
Daneel is offline   Reply With Quote
Old 06-23-2014, 05:53 PM   #2
Rewards Points: 127
There is also a run from the bonded neutral to a ground rod near the main panel.
Old 06-23-2014, 07:08 PM   #3
Rewards Points: 6,652
You can use that old Galvanized pipe with the ground wire as a ground. It would fall under grandfathered rules, as it stands.
You will always have in most main panels the grounds and Neutrals bonded together, then have it grounded at the meter pan.
If you have the ground rod ground inside the main panel. You need to separate the neutrals and grounds. The Neutrals need to be placed on bus bars, that are not bonded to the grounded metal of the panel and ground bus bars.
Old 06-24-2014, 06:15 AM   #4
Licensed electrician
Rewards Points: 1,478
Simply because the GEC terminates in the panel does not mean the neutrals and grounds need to be separated. A service panel can share the bus between neutrals and grounds.
brric (06-24-2014)
Plumbing pipe internal diameter digitalplumber Plumbing 5 10-16-2012 01:43 PM
Cutting and gluing PVC pipe to washer steve3847 Plumbing 8 10-03-2012 08:00 AM
Buried gas pipe in conduit WillK Plumbing 4 01-07-2011 12:50 PM
tiny hole in plumbing pipe phospher Plumbing 24 11-18-2009 03:30 PM
plumbing leak or pipe sweat? wombosi Plumbing 4 10-03-2009 04:01 PM
