Old UF Cable, 12-2 With 14ga Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 02-26-2008, 02:05 PM   #1
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
Old UF cable, 12-2 with 14ga ground
I have some old 12-2 UF cable with a 14 ga ground conductor. I want to use to extend an existing 20 amp circuit from my garage to a small shed for a light and one outlet. Is this a code issue? I also could downgrade the garage circuit to 15 amps (change out breaker) as there is very little load on this circuit. I hate to throw the cable away and buy new with the price of copper wire these days.
rjniles is offline   Reply With Quote
Old 02-26-2008, 05:54 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
believe it or not but there is no way to legally install that cable anymore.
a 15 amp circuit requires #14 cu ground wire and a 20 amp circuit requires a #12 cu ground wire BUT if you upsize the conductors, the EGC must also be uspsized to match the power conductors capabilities.
So, what that means is even if you put it on a 14 amp breaker, you would still need a #12 ground because the power conductors are #12 and they could be connected to a 20 amp breaker for which #12 cu EGC is required.
That is the legal answer.
Old 02-26-2008, 09:42 PM   #3
Res Ipsa Loquitur
Don't throw it away- Find a copper scrap dealer to sell it and use the correct cable you need.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 02-26-2008, 11:12 PM   #4
Just use it.
220/221 is offline   Reply With Quote
In-Floor Heating Cable Trouble... sootybuttercup Electrical 24 12-18-2014 08:01 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Ground rod blues!!! ra_doliv Electrical 8 09-02-2007 11:48 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
