Old 02-08-2008, 10:31 PM   #1
old stove new outlet
I have an older stove with a 3 wire 3 prong pig tail. I have a 4 prong outlet, what are my options?
homebuilder is offline   Reply With Quote
Old 02-08-2008, 10:39 PM   #2
Electrician
You only have one option go get yourself a 4wire range cord...
chris75 is offline   Reply With Quote
Old 02-09-2008, 01:54 AM   #3
My License Ain't 4 Sale..
Don't forget that there is a neutral bond inside the range that needs to be disconnected when installing the new cord.
InPhase277
Old 02-09-2008, 02:54 AM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Yes ...critical what inPhase mentioned about the bond from the neutral terminal to metal of the dryer frame. When you have that darn much metal it is great that you have the option to get the neutral bond removed from the dryer frame. Glad you have that 4 wire existing. Diagram (s) below. Click the diagrams to enlarge. This diagram is meant as a guide and does not preclude electrical common sense. If in doubt secure the help of a knowledgable person. The neutral/chassis bonding means varies from dryer to dryer two examples are shown below, the bottom diagram shows the strap being removed and then utilizing the the fastening point of the strap to the metal frame to secure the new ground wire in the 4 wire dryer cord. The task here if it is not obvious is to not have the metal frame of the dryer connected electrically to the neutral terminal and thus to the neutral of the power supply. The 4 wire cord and four wire supply allows you to accomplish this modification.
old stove new outlet-dryer-4-wire.jpg   old stove new outlet-4-wire-ge-range.jpg
Wiring stove outlet in old house electric-pete Electrical 23 07-06-2008 04:02 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
20a Outlet Vs. 15a Outlet bobo Electrical 3 05-29-2006 11:55 PM
Adding garage outlet Shane Electrical 1 02-23-2006 05:43 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
