Old Outlets To Be Upgraded - Electrical - DIY Chatroom Home Improvement Forum
Old 11-06-2008, 11:07 PM   #1
Old outlets to be Upgraded
Wondering how to go about replacing the old two prong outlets with the standard grounded outlet. What do I ask for at the store? Thanks!
RemodelMan is offline   Reply With Quote
Old 11-06-2008, 11:42 PM   #2
You need to use a gfci unless you have bx (armored cable) with a bonding strip inside.
Using a gfci will NOT give you an equipment ground, but will let you use 3 prong equipment.
If the outlets are wired in a series, put one at the begining and then replace the rest with 3 prong connected to the "load" side of the gfci.
rgsgww is offline   Reply With Quote
Old 11-07-2008, 12:20 AM   #3
Thanks, I do happen to have bmx cable. What type of outlet do I ask for to retrofit these?
Old 11-07-2008, 08:04 AM   #4
Rewards Points: 6,652
The best thing is if you can afford it, hire an Electrician to replace. Otherwise, pretty much standard, and depends on how much you can afford to do it yourself.
Old 11-07-2008, 10:00 AM   #5
Electrician
In series? That may confuse someone. Also, you could just replace the breakers with GFCI breakers, usually alot easier IMO.
chris75 is offline   Reply With Quote
Old 11-07-2008, 11:18 AM   #6
Oh, I didn't notice that. I meant from receptacle to receptacle. Depends on the brand of breakers though. Square d makes some expensive qo series breakers...
Old 11-07-2008, 11:19 AM   #7
Does this cable have fabric in it? does it have a small aluminum wire in it?
Old 11-07-2008, 11:20 AM   #8
Electrician
Oh, I didn't notice that. I meant from receptacle to receptacle. Depends on the brand of breakers though. Square d make some expensive qo series breakers...
Yep, thats why I only sell GE, very reasonable if you ask me, and perfect for the residential world.
Old 11-07-2008, 11:31 PM   #9
Outlet upgrade
I asked a local electrician, he said I need self grounded outlets on account of the fact I have bmx. Thanks guys, I appreciate your input...
Old 11-08-2008, 08:06 AM   #10
Electrician
Thats great, but you still need to see if your BX contains a bonding strip, depending on the year the wire was manufactured it may not, if this is the case, then you cannot use the jacket as a grounding conductor.
Old 11-08-2008, 08:19 AM   #11
outlet upgrade
Ahh, thanks Chris, good to know that! I had no idea. I'll look for the little wire, i have seen those elsewhere and wondered what it was about.....
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 01:29 PM
GFCI switch to control outside outlets billgeo Electrical 14 09-09-2008 12:09 AM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 09:37 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 07:02 AM
