Old Outlet Attached To Gfci Downstairs - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-13-2013, 01:45 PM   #16
FYI - A GFCI is like a bank teller. It "counts" how much electricity is going out one wire and coming back on the other wire. If some electricity is "unaccounted for", then the GFCI instantly shuts off the electricity!
So if someone was electrocuted, "some" of the electricity would flow through their body to "ground". Then the "bank teller" would notice some electricity "missing" and instantly shut of the electricity on the GFCI outlet.
A GFCI tester simulates this by leaking a small amount of electricity to the 3rd ground prong of the outlet. That will not work if that 3rd ground prong is not connected to anything. However the GFCI tester should work just fine in the GFCI outlets below the panel (with new wire going to them).
How a GFCI works...
http://ecmweb.com/content/how-gfcis-work
Billy_Bob is offline   Reply With Quote
The Following User Says Thank You to Billy_Bob For This Useful Post:
TTW (01-13-2013)
Old 01-13-2013, 03:42 PM   #17
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,252
Originally Posted by TTW View Post
It is current code to use gfci's to protect 2 wire ungrounded outlets.
I have done this in my own house, but in my case I was able to replace the first receptacle in the chain with a gfci outlet.
The remaining outlets are required to be marked 'no equipment ground' and 'gfci protected outlet'. These stickers actually come with the gfci outlets for exactly that purpose.
White receptacles with ivory covers? Tacky
Oops, I have a few in my house
Coastal South Carolina
Old 01-13-2013, 05:06 PM   #18
Electrical Contractor
kbsparky's Avatar
What your electrician did was make the circuits safe -- for humans. You are now protected from errant ground fault conditions, since you obviously had 3-prong outlets connected to non-grounded circuits.
While this procedure protects YOU -- the occupants of the house -- it does NOT protect your equipment! Things like plug-in surge devices will not work properly connected to these older non-grounded circuits.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
joecaption (01-13-2013)
Old 01-13-2013, 05:19 PM   #19
Rewards Points: 14,300
Exactly what I was thinking. Sounds like he took the easy way out.
Old 01-13-2013, 06:37 PM   #20
joed's Avatar
Rewards Points: 13,708
He may have taken the easy way out but what he did is perfectly to code and would pass an inspection.
It depends on what you requested him to do and what the contract said as to whether he fulfilled what you hired and paid him to do or not.
Old 01-14-2013, 10:25 AM   #21
RST
DIY Homeowner
Rewards Points: 150
He could have turned the first receptacle on each circuit into a GFCI instead. This would have looked better but then you would have had to hunt around for the correct GFCI whenever one tripped. There are plenty of threads on here from people hunting for GFCIs. These are more accessible and they are all in one place.
Plus GFCIs are bulky and your existing boxes may be too small.
RST is offline   Reply With Quote
Old 01-14-2013, 11:06 AM   #22
Originally Posted by RST View Post
He could have turned the first receptacle on each circuit into a GFCI instead...
But with an old house, finding those first receptacles could have taken many hours of the electrician's time. And that would have cost the OP more money.
Thus another reason why I like the idea of placing the GFCI's under the panel for the old wiring.
Circuits in Garage and GFCI tedallen Electrical 19 05-24-2012 07:03 PM
10 amp Vacuum popping GFCI Outlet brgmgb Electrical 19 12-29-2011 10:45 PM
Flourescent light using GFCI outlet Willing2learn Electrical 5 09-12-2010 07:27 PM
GFCI outlet feeding sub panel tdola Electrical 1 07-13-2010 02:15 PM
Problems with GFCI Outlet FieldersChoice Electrical 11 01-04-2009 01:53 PM
