Old 10-31-2012, 11:41 AM   #1
Old NM/Romex with Small Gauge Ground
I had two ungrounded receptacles fed from a single 14-2 NM/Romex. When I opened the junction box, I found two issues. The first was that all of the ground wires for the other branches were just twisted together with no wire nut. I fixed that as well as added a ground screw to the metal box.
The other issue was that the ground wires on the branches were all smaller gauge wire. They looked to be 16 gauge. Did NM/Romex used to have undersized ground wires? Should I be concerned?
brgmgb is offline   Reply With Quote
Old 10-31-2012, 12:04 PM   #2
Julius793's Avatar
Yes they used to be smaller but not a concern.....I've lost quite a few dykes to these undersized grounds :-)
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 10-31-2012, 02:06 PM   #3
Code05's Avatar
IIRC, full sized grounding wires for circuits using #14, #12, and #10 were first required in the 1971 NEC.
Code05 is offline   Reply With Quote
Old 10-31-2012, 05:59 PM   #4
You can keep the wiring as-is but you may not extend the circuit to additional receptacles, etc. while relying on the existing cable with thinner ground to complete the path for the new wiring back to the panel.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 10-31-2012, 06:10 PM   #5
Julius793's Avatar
Article # please!!??
Old 10-31-2012, 07:54 PM   #6
A "Handy Husband"
rjniles's Avatar
Not true. You can not extend non grounded circuit. This circuit has a ground and can be extended.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 10-31-2012, 08:57 PM   #7
But it doesn't meet the minimum size for a ground as per 250.122
Could be considered as 'not a ground', up to AHJ.
Techy is offline   Reply With Quote
Old 11-01-2012, 01:46 AM   #8
Julius793's Avatar
Doesn't make a difference it's grandfathered in as a grounded circuit.
Old 11-01-2012, 06:08 AM   #9
It's only grandfathered if you leave it as is, down here.
Once you 'change' it, it must meet current code.
Spark Connecting Ground on light fixture RonaldD Electrical 12 01-10-2012 08:58 PM
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 03:06 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
