Old Meter Base And 100 Amp Breaker Shutoff - Electrical - DIY Chatroom Home Improvement Forum
Old 06-11-2012, 06:56 PM   #1
old meter base and 100 amp breaker shutoff
I need to replace my meter base- the dimensions are 15 inch wide 10 inch tall and 4 inches deep. the housing is in two sections- the meter base is on the left side- the 100 amp breaker is on the right side and the wires route from the breaker into the house to the main panel. the problem I have is that the clip on the bottom is stripped and can not be tightened. Any suggestions on where to find a replacement? I can't locate anything on line.
DA3dux is offline   Reply With Quote
Old 06-11-2012, 07:06 PM   #2
Licensed electrician
Rewards Points: 1,486
Sounds like you have an all in one combo. If the socket needs to be replaced you probably need the whole unit.
Old 06-11-2012, 07:06 PM   #3
Rewards Points: 13,450
No DIY should be messing with the meter base.
If fact most places require a permit.
Old 06-11-2012, 07:52 PM   #4
Rewards Points: 330
could also be a 100 amp meter main.
oleguy74 is offline   Reply With Quote
