Old Man Running Electrical To Workshop - Electrical - DIY Chatroom Home Improvement Forum
Old 08-29-2013, 10:54 PM   #1
Old man running Electrical to workshop
My son has a workshop that's 150 feet from his house. He has 100 amps going into the main house (rural) and 200 amps to an outside panel below the meter (on the house). I would like to run 100 amps to his workshop for him from this outside panel. It seems straight forward to me, but I thought I would get your advice, I read the columns religiously (I'm old). I plan on trenching down 18 inches. Then from the house, running metal conduit 4 feet across and then down (I'm trying to avoid cement that's below the panel/meter. I'd then switch to non metal in the trench from a 90 elbow. THe trench will need to turn a few times to avoid trees/driveway. I will run 2/0 AL 4 single wires (2 hot, neutral,ground) to a subpanel at the workshop. I'll unband the ground and neutral bars, run rods (2) out 6 feet and go down 8 feet with them. From there, I'm good with the workshop wiring. Did I miss anything? I grew up before "neutral" was a necessity, everybody said they were just trying to sell more Cu. Thanks a bunch.
Screwitharder is offline   Reply With Quote
Old 08-30-2013, 07:04 AM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Neutral was always a necessity. The terminology is what confuses everyone...
Old 08-30-2013, 07:11 AM   #3
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
1) With just 4' across the house, I would just run PVC the whole way.
2) With 2/0 ungrounded conductors, you could go with a 1/0 neutral and a #2 ground. All 4 @ 2/0 would be overkill.
3)If your trench will turn a few times, plus a 90 going in and a 90 coming out, I would just go another 6" and use direct burial wire and just use pipe in and out of the ground. You'll play hell pulling that length and size wire in too many bends.
You mean ground
wirenut1110 is offline   Reply With Quote
Tags
conduit , electrical , subpanel , trench , wiring
running Electrical wire/ethernet alongside natural gas line lazzz Electrical 15 03-22-2013 07:26 AM
Running electrical wire jyalbert Electrical 15 04-30-2011 05:07 PM
Running electrical wire into 98 Buick Lasabre Red Squirrel Automotive Repairs 5 04-22-2010 10:08 AM
running underground electrical, communication, and water Chavez Electrical 4 04-05-2009 01:45 PM
Electrical wiring running parellel and through ductwork? Beren Electrical 1 06-01-2007 05:08 PM
