Old Low Voltage Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 01-20-2007, 11:58 AM   #1
Hi All, I have an old house built back in 1962 and it has a Low Voltage Wiring system! The old Remcon relays are starting to fail and I have been replacing them with Remcon Amprobe #R-115s. And now I'm trying to find replacement switches and cover plates.
Looking for help on locating switches and cover plates that will work with my old system. The relays have the 3 low voltage wires that lead to my switches. My old switches are the Momentary rocker type with 2,3 and 4 gang switches throughout the house. My goal is to replace all of them. Hope someone on the forum might be able to lead me in the right direction, Thanks in advance Scott
srwjr is offline   Reply With Quote
Old 01-20-2007, 10:10 PM   #2
remodeling pro
Hey pal, things that originated in 1962, like your house, or even 11 years earlier, like me, are not "old". Seriously, I have never seen an entire house wired with low voltage. Sorry, no help, but just couldn't pass up the smart ass comment. Good luck.
troubleseeker is offline   Reply With Quote
Old 01-21-2007, 08:38 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
I know you can get the relays, you obviously do as well, but I have not seen the switches. You may have to build something yourself out of stock toggle/bat/rocker type switches and blank plates.
Those systems were fine back in the day but I wonder if they had any long term predictions of what would happen 40 years later.......
Old 01-21-2007, 10:57 AM   #4
Thanks for your interest in my post on the Low Voltage Wiring, Yes the entire house is wired with the low voltage, Honestly its not a bad system, and kind of neat being able to close the Garage Doors and turn off all lights from the Master Bedroom and being able to see if any lights were left on in the house or outside (when they are all working OK.) back then it was only available on High End houses, Now that I found the Relays everything is working as intended. my quest for switches and cover plates is cosmetics as they are all working OK, but through the years they become faded and cracked. Your right I guess a 45 year old home isn't really old but its up there. Scott
Old 01-21-2007, 01:49 PM   #5
srwjr,
Do the individual wall switches have two wires or three wires?
There are standard wall switch replacements with a conventional look for two-wire switches.
...Christopher
Christopher is offline   Reply With Quote
Old 01-21-2007, 02:29 PM   #6
Originally Posted by Christopher View Post
srwjr,
...Christopher
Mine have the 3 wires from the relays to the switches,
with 2,3 and 4 gang switches in the wall box and they are throughout the house. my relays are the Amprobe #115s. Scott
Old 01-21-2007, 03:34 PM   #7
Any single pole double pole center off momentary switch will work.
Here is an example: http://www.leviton.com/OA_HTML/ibeCC...?a=b&item=2857
jwhite is offline   Reply With Quote
Old 01-22-2007, 01:53 PM   #8
Your right about the switches working but to do so I would need to do a lot of plaster work as the switches won't fit in my situation, my low voltage switches are only 5/8 inch wide and there are 2,3or4 switches per location, the standard switches are just too big. so the hunt continues.
Old 01-23-2007, 05:27 PM   #9
They make mini toggle switches like what you want.
Old 01-23-2007, 05:54 PM   #10
Check out these McMaster-Carr part numbers.
7246K19
7343K783
You will need to make your own covers to install the switches in. Sounds like a fun weekend project.
Old 01-24-2007, 10:30 AM   #11
I've got good news to report! I found a Co. that manufactures low voltage system's and they have a retrofit switch/cover plate that will work with the old low voltage systems like mine!! I will need to do a little plaster work but not too bad. their mountings are more like standard switch's, where as mine are turned sideways, not sure I'm explaining this right but anyway they will work. the Co. is Touch-plate Lightling. www.touchplate.com/ Thanks for all the replays trying to help, you guys rock!!
Old 01-24-2007, 01:07 PM   #12
srwjr,
Thanks for the link.
I thought that you needed 3-wire switches. Everything I saw there was 2-wire, perhaps I missed something.
...Christopher
Old 01-24-2007, 02:57 PM   #13
srwjr,
...Christopher
Christopher, Go back into the link and check out the switch page, look at the ECL (Eclipse) series and read the features and you will see they are compatible with the older 3 wire relay system. now when I called the customer technical guy he told me the LED switches won't work with mine only the non LED switch will work. Regards
Old 01-24-2007, 03:19 PM   #14
Scott,
Yes, I see.
What they are saying is that you need a 2-switch unit per existing 3-wire switch. One new switch turns the light on, the second new switch turns the light off. This is not exactly unique to the ECL (Eclipse) series but that series makes the most sense.
...Christopher
Old 01-24-2007, 08:29 PM   #15
Check out this web site
http://www.alltestequipment.com/cgi-...&action=search
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Troubleshooting bedroom outlet wiring? Operator4819 Electrical 15 04-01-2007 09:10 PM
Low voltage to vacuum l.schrankel@comcast.net Electrical 2 03-04-2007 10:38 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
