Old Low Voltage Wiring
Hi All, I have an old house built back in 1962 and it has a Low Voltage Wiring system! The old Remcon relays are starting to fail and I have been replacing them with Remcon Amprobe #R-115s. And now I'm trying to find replacement switches and cover plates.
Looking for help on locating switches and cover plates that will work with my old system. The relays have the 3 low voltage wires that lead to my switches. My old switches are the Momentary rocker type with 2,3 and 4 gang switches throughout the house. My goal is to replace all of them. Hope someone on the forum might be able to lead me in the right direction, Thanks in advance Scott |
Hey pal, things that originated in 1962, like your house, or even 11 years earlier, like me, are not "old". Seriously, I have never seen an entire house wired with low voltage. Sorry, no help, but just couldn't pass up the smart ass comment. Good luck.
I know you can get the relays, you obviously do as well, but I have not seen the switches. You may have to build something yourself out of stock toggle/bat/rocker type switches and blank plates.
Those systems were fine back in the day but I wonder if they had any long term predictions of what would happen 40 years later....... |
Thanks for your interest in my post on the Low Voltage Wiring, Yes the entire house is wired with the low voltage, Honestly its not a bad system, and kind of neat being able to close the Garage Doors and turn off all lights from the Master Bedroom and being able to see if any lights were left on in the house or outside (when they are all working OK.) back then it was only available on High End houses, Now that I found the Relays everything is working as intended. my quest for switches and cover plates is cosmetics as they are all working OK, but through the years they become faded and cracked. Your right I guess a 45 year old home isn't really old but its up there. Scott :wink:
srwjr,
Do the individual wall switches have two wires or three wires? There are standard wall switch replacements with a conventional look for two-wire switches. ...Christopher |
with 2,3 and 4 gang switches in the wall box and they are throughout the house. my relays are the Amprobe #115s. Scott |
Any single pole double pole center off momentary switch will work.
Here is an example: http://www.leviton.com/OA_HTML/ibeCC...?a=b&item=2857 |
They make mini toggle switches like what you want.
Check out these McMaster-Carr part numbers.
7246K19 7343K783 You will need to make your own covers to install the switches in. Sounds like a fun weekend project. |
I've got good news to report! I found a Co. that manufactures low voltage system's and they have a retrofit switch/cover plate that will work with the old low voltage systems like mine!! I will need to do a little plaster work but not too bad. their mountings are more like standard switch's, where as mine are turned sideways, not sure I'm explaining this right but anyway they will work. the Co. is Touch-plate Lightling. www.touchplate.com/ Thanks for all the replays trying to help, you guys rock!! :thumbup:
srwjr,
Thanks for the link. I thought that you needed 3-wire switches. Everything I saw there was 2-wire, perhaps I missed something. ...Christopher |
Scott,
Yes, I see. What they are saying is that you need a 2-switch unit per existing 3-wire switch. One new switch turns the light on, the second new switch turns the light off. This is not exactly unique to the ECL (Eclipse) series but that series makes the most sense. ...Christopher |
| All times are GMT -4. The time now is 01:10 PM. |
