Old Low Voltage Lighting System - Switches Stopped Working. - Electrical - DIY Chatroom Home Improvement Forum
Old 03-31-2012, 11:36 PM   #1
Old low voltage lighting system - switches stopped working.
Hello,
I've lived in my grandparents' old home for over 10 years now and came upon a problem last week with the lighting system. My grandfather was an electrician and when he built the home in the late 60's, he installed a low voltage lighting system (I believe a GE system) for several of the rooms. Last week every switch on the system stopped working and I could not turn the lights off in those rooms. This system has a relay at every fixture as far as I can tell and rocker switches on the walls. I'm guessing that the transformer went bad, but I've been reading a few posts that suggest stuck light switches can sometimes be the culprit. I don't know if this applies to my system, however, and wondered if anyone had any suggestions. I know this system is extremely dated and few people work with them, but any help would be appreciated.
zepman is offline   Reply With Quote
Old 04-01-2012, 12:25 AM   #2
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by zepman View Post
Hello,
If any of the low voltage switches do not work then most likely the transfomer is shot you will have to find it in few different location depending on the set up it can be in basement or attic or one of the wall in garage or ulity room one of the three locations typically found.
For the transfomer do NOT use standard 16 volt doorbell transfomer the voltage is too low to activie it so you use the 24 volt transfomer ( 40 VA is most common size ) some case you may have two transfomers in there so just give you a head up with it.
The most common relay is GE RR7 or RR5 depending on the switch conferation is.
I will post the photo what it look like real quick so you will know what to look for.
The low voltage conductor will useally be outside of the junction box while the line voltage conductors will be inside the junction box. ( this will be little tricky to do the troubleshooting when you do the Line voltage side so make sure the circuit you work on is off first )
Hope that should help you with this one.
Merci,
Marc
The Following 2 Users Say Thank You to frenchelectrican For This Useful Post:
MTN REMODEL LLC (04-14-2014), zappa (04-02-2012)
Old 04-01-2012, 12:43 AM   #3
Thanks for the quick reply Marc! My father and I worked on the system a little today and have located the transformer. It is in the attic. He had a spare transformer he had ordered several years back, since his house uses a similar low voltage system as well (my grandfather installed both systems). The transformer he has, however, looks slightly different than the one in the attic, but we think it will work. We just want to make sure the wiring is correct. The old transformer has a large black wire and white wire spliced into the main power source and two screws on top of the transformer with 3 black and green wires going to one screw and 2 white wires going to the other screw.
The new transformer is similar and looks like the one in the link below.
http://www.kyledesigns.com/product/R...ansformer.html
Old 04-01-2012, 12:48 AM   #4
Also, I started thinking about changes we have made to the system over the years. Last year, I installed a ceiling fan in place of chandelier lights that were originally on the system and wondered if that could also have any effect on anything. I still used the same relay and rocker switch for it though.
Old 04-02-2012, 12:31 AM   #5
I think it should not affect but I do not have the rating listing with me but IIRC they should handle the motour load without issue like your ceiling fan that don't draw much current at all.
Merci,
Marc
Old 08-02-2013, 11:07 AM   #6
Unhappy
Similar Issue
This morning, I tried to turn on my daughter's light and it would not come on. We also have the relays from the 50's 60's or 70's. If I held the rocker switch on, it would flicker but would not turn on. After playing with this for quite some time, I finally got the light to come on. Now that it is off, I can not get it to come on again. It does flash but will not turn on. There are two switches in the room and neither will turn on the light. It is the only light in the house that is malfunctioning. Any suggestions? Thanks.
Keith
KKing is offline   Reply With Quote
Old 08-02-2013, 10:42 PM   #7
Keith
Bonjour Keith.,
The flicking light useally tell the relay concats are going bad so that is one of the most common cuprit.
You will have to find where the low voltage relays are located but typically useally in attic or basement and some case in garage as well ( only if attached garage.)
Check the power at the relay ( you will have to find which one is used for that room ) and see if you can bypass if the luminaire do come on full brightenss without flickering then the relay is bad.
Also the other common cuprit is worn out low voltage switch ( you will have to pay attetion to the connections on this one and type of low voltage switch by either mantained concant or mometeary concants < Most common is mometary verison >
So replace the relay then switch to see if that clear up.
Merci,
Marc
Old 04-14-2014, 07:31 PM   #8
A New issue with the GE relay
The other day we had all of the switches stop working. If the lights are on they won't go off and if they are off they will not go on. There is 28 volts coming out of the transformer. It goes to some sort of resistor and then to one large relay, which appears to be a RR4, now replaced with RR9. We have replaced the relay and still no good. I would not be led to believe that all relays burned out at once. While exchanging the RR9, a light that was previously off is now on but will not go back off. Any ideas what would cause all of the switches to stop working either in the on or off positions? Thanks.
Keith
Old 04-14-2014, 07:54 PM   #9
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,388
Gentlemen.....
4-5 years ago, my wife sold a home to friends, who had several lights go out, and called me. It was a low voltage (switches) system.
I had never seen one before.
What is/was the benefit to a low voltage switching system.??????
TIA
Best
( I subsequently figured it out, don't remember the make, but found the relays that had failed, and replaced them. It was very nicely/expertly run.
As I recall, those relays were $35-40. Just noticed this OP's transformer was $150. I don't understand the advantage of this type system???)
MTN REMODEL LLC is offline   Reply With Quote
Old 04-14-2014, 07:58 PM   #10
All relays went out
I do not believe that all of the relays went out at once. It seems that there must be one central location. Because every light in the house/garage that go through the relays no longer work, once again, if they are on, they will not go off and if they are off they will not go on. This does not seem like all the relays, and there are a lot of them, burned out at exactly the same time. thanks.
Keith
Old 04-16-2014, 06:49 AM   #11
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
If a button sticks, it will cause havoc on the entire system.
Old 08-24-2015, 01:30 PM   #12
Rewards Points: 2
I am having a different problem with my low voltage switching. I went to turn on a light switch (actually 2 at the same time) and all my lights went off. I then went and checked my circuit panel and a breaker was tripped labeled "relays." I tried to reset the breaker, but it will not reset. Any idea what could be causing my circuit to my relays to be shorting??? I only have one relay box and it is pretty neat inside. I have an electrician coming over later, but he doesn't seem to know too much about low voltage systems. Thanks so much!!!
Mikeer50 is offline   Reply With Quote
Old 08-24-2015, 01:57 PM   #13
Rewards Points: 1,666
Mikeer50,
Best to start your own thread, this one is 3 yrs old.
bob22 is online now   Reply With Quote
Old 02-17-2016, 01:29 PM   #14
Rewards Points: 2
Diagram, photo, anything?
Hey Guys - Do you think there're any diagrams available covering this stuff? If so, where would one find them? We just moved into a home in MD. that was built in the '50's. I went in the attic, ... I've never seen such a mess of wires, relays, ... HOLY SMOKES !!!!! Any idea on how to identify model or what ever? I "think" this is GE stuff. Emphasis on "think".
Scitnor is offline   Reply With Quote
Old 02-17-2016, 07:18 PM   #15
Master Electrician
Rewards Points: 3,918
https://www.google.com/search?q=ge+r...HfAhA5oQsAQIFA
brric is online now   Reply With Quote
VERY EERIE! Remote garge door openers and both car remotes stopped working! proofer Automotive Repairs 16 12-03-2016 08:31 AM
outlets in garage and exterior outlet stopped working littleturley99 Electrical 16 07-10-2011 10:08 PM
Need to fix line voltage outdoor lighting noone Electrical 5 05-19-2011 11:49 PM
lighting automation christy123 Electrical 10 03-07-2007 04:18 PM
Zone system not working with heat. deliriousga HVAC 5 12-29-2006 06:04 PM
