Old Lighting Fixture Up To Code? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-18-2012, 12:32 PM   #1
Old lighting fixture up to code?
I have this old lighting fixture in my basement and i'm not sure if its up to code since the back is wide open. Can I mount this flush to a 2x4 or do I need to use some kind of a box? Or should I just buy a new one that is more safe?
Thanks!!
Old lighting fixture up to code?-img00042-20120818-1225.jpg   Old lighting fixture up to code?-img00043-20120818-1225.jpg
badfish is offline   Reply With Quote
Old 08-18-2012, 12:36 PM   #2
Rewards Points: 1,418
Use a 4 inch (diameter) octogon or round box into which the power cable enters. Then mount that porcelain fixture on the box.
(You can also use a "pancake box", that is about 4 inches in diameter and about 3/4 inches deep, if there is just one 14-2 cable coming in and no cable continuing to a (the) next light etc.)
All ceiling light fixtures of any vintage need a box in the ceiling nowadays. They still make that porcelain fixture you have pictured.
Old 08-18-2012, 02:08 PM   #3
thanks a lot for your help!
Old 08-18-2012, 06:49 PM   #4
Rewards Points: 6,652
Nothing old about that. Porcelain heads are still manufactured, due to they are favored over the plastic heads.
Old 08-18-2012, 07:06 PM   #5
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Thanks!!
They are what we call a "keyless" or "Russell" and will mount to a 4" metal octagon or 4" round plastic nail on box. Never use them in a clothes closet. Commonly found in basements, garages, attics and crawl spaces everywhere. A favorite with builders until the HO chooses or provides their light fixtures. Plastic ones are better because they don't break if over tightened.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-18-2012, 07:49 PM   #6
Rewards Points: 12,830
If you want some real light install a 2 X 4 box instead and just buy a cheap plug in 4' flouresant fixture. Far more light and cost less to run.
Automatic Closet Lights Sav505 Electrical 52 12-28-2012 08:24 AM
Rim around lighting fixture fell off. HELP rbrtadlsn Electrical 2 05-23-2012 07:07 PM
Mounting Lighting Fixture onto Mirror ostinoh Kitchen & Bath Remodeling 5 02-01-2012 06:25 PM
Lighting fixture wont turn off Fedup Electrical 5 10-18-2011 11:02 AM
double-ended halogen fixture bulbs stop working watt-ever-ny Electrical 6 11-20-2007 06:25 PM
